The block diagram in the video is for a system quite different from yours. It just happened to be the first example of a block diagram I could recall. I wanted just to illustrate the concept.
On that diagram, the blocks have a particular function, such as "amplifier", "mixer", "splitter", "filter", "switch", and so on. Each block is represented by what it does, not by how it is made. By joining up those building blocks and showing how the signal is conveyed through them it becomes possible to show the functioning of the complete system.
Each block is actually built out of more primitive circuit elements (resistors, capacitors, transistors, ICs) that would actually appear on the circuit schematic.
The block diagram from that video can fit on a single page and can be followed by a someone tracing through it, as Shahriar showed. The full circuit schematic would be much larger and more complex, and would be hard to follow without the block diagram as a guide.
For your particular circuit, you should I think be able to describe what it does from input to output. You take one or more input signals, you do something with them (buffering? combining? delaying? switching?, ...), and you generate one or more output signals. Even if you don't have a block diagram, your circuit schematic would still benefit from having a continuous "flow" from inputs to outputs, rather than being shown as several unconnected panels.
