Hello!
I am not very experienced in the use of schmitt triggers (experience=0) and designed a circuit.
For my application, I need 3 channels but I don't want to have an inverted signal.
I have used a 74HC14D (NXP) which has 6 channels.
To not have an inverted signal, I have connected the output to the input of an other channel of the chip. Therefore, in my theory, the signal should be inverted again.
It is not a nice solution, I know, but I thought, I could just use those 3 spare channels because I don't need them anyway and save using an inverting circuit.
BUT!
It doesn't work.
I have made some PCBs and tried it out, but no matter which input signal I put in, the output is high all the time.
Can somebody help?
Is my circuit not possible, or ist the error somewhere else?
(I am using it in my 3D Printer, maybe I am reading it out wrong. I will make some measurements now.)
Thankyou very much!
Julian.
