I have a signal that varies between 1v to 12v, ie 1v, 2v, 3v, 4v, 5v, 6v, 7v, 8v, 9v, 10v, 11V, 12V, but the amp is so small that it can not drive the load in the other end so I have to increase the amp, so when the signal in is at 3 Voltage so is the utput on 3 Voltage 8A for example
