Thank you. Exactly the kind of thing I was looking for. I can google search on some of the terms you provided for more detail. I don't understand the "3.4 degrees shy of full circle" remark. That's an awful specific number. Full circle? Aren't we talking about half a circle with SCRs? If I can fire the gate at 7 volts (3.4 degrees?), I'd consider that close enough to zero and a success, especially if an alternate power source wasn't required to fire the gate.
"Full circle" assuming you use a pair to fill in the full cycle. I guess... you haven't indicated exactly what it is you're switching, and how you want to switch it (half wave, full wave, partial..)?
I was guessing about 1V for turn-on, which means it can't tun on until 1/30th, or 1.9 degrees. Actually.. now I wonder if I did that wrong but got a roughly correct answer anyway...
Maybe there was a sqrt(2) in there, too. Since it's not clear if you're speaking of 30V RMS AC, or 30V peak, or even something arbitrary.
Likewise, it turns off below a similar voltage, doubling it to 3.8 degrees. Actually, that should be "half circle", although if you're only talking about one SCR, there's no other half to the circle to speak of, so I guess that's still true in a manner of speaking. A complementary pair would miss a total of 7.6 degrees though.
But anyway yeah, if it's self driven, it has to have some dropout somewhere.
Using a BJT... wouldn't that still be the same problem?
No, I meant it behaves like one. You'd have to provide external drive to keep it going under that condition (I
load < I
[h). Which could be an external gate driver, isolated power, transformer coupled, you name it.
10s of uSeconds is plenty fast enough for a 60Hz input. I don't need any better resolution than that. BTW... I don't understand the last parenthetical statement. Does it contain grammatical errors?
No, I mean:
Power source -- load -- SCR (A to C) -- GND
Opto is a HV phototransistor type, collector to SCR anode, emitter to SCR gate.
Except, if voltage reverses, so does the transistor, which is bad. So it needs a series diode.
So your minimum dropout is Vce(sat) + Vf + Vg(on).
An optoisolator acts roughly as a constant current source, so this should turn on the SCR fairly easily, independent of operating voltage. The transistor can potentially dissipate a lot of peak power (like 10mA * 100s of V -- in general SCR applications, not for your case), though the pulse width should be small (the SCR should turn on in a few microseconds), and has relatively high capacitance (a G-C resistor and C-G diode would help protect against transients and leakage). For general SCR applications anyway, you'd probably need a darlington (photo- or otherwise), to deliver enough gate current to get it running, since bigger SCRs aren't as sensitive (>50mA Ig(max)?).
