Author Topic: Second-hand TDS-340AP oscilloscope get!  (Read 2863 times)
Offline houkensjtu
« on: May 22, 2015, 04:17:21 pm »
Hi!
I found this bad boy in local market, cost me about 130 dollars. It's my first oscilloscope! LOL
Its spec is quite high-end for beginner I think, features 100MHz bandwidth, 500MS/s sampling rate and even more, it comes with a GPIB capturing card!
What I'm little disappointed about is, this guy is over 45cm in depth!! That's gonna be really hard for me to find a proper place on my working bench for it.
For the time being I still don't have idea on how to play with, maybe I will use it to observe my hand-made experiment power supply behavior.
Post anything you thought!
Offline tron9000
  • Still an Electronics Lab Tech
    • My Hack-a-day project page
Re: Second-hand TDS-340AP oscilloscope get!
« Reply #1 on: May 22, 2015, 05:55:24 pm »
GPIB is something I've not used, but from my experience, its something NOBODY ever used. We got some nice Tektronix TBS1052's in our labs and the software to get screen grabs off them is default set to bloody GPIB! Why?! when it has a perfectly good USB connection to use!! :rant:
....coming back on track, 45cm, meh, for anyone who's owned a traditional CRT, this has always been an issue, you find a way to make it fit, least you don't have it this bad:
(this is a movie prop - it could be the machine that goes PING!)
Most importantly - do you have a good set of probes?
Partsbox.io - orangise your parts!
"If you're green you can only ripen. If you're ripe you can only rot!"
Offline dom0
« Reply #2 on: May 22, 2015, 07:36:29 pm »
Not true. Also, USB sucks for multiple reasons (extensive driver headaches, unreliable connections, bad platform compatibility (cf. driver headaches))
Offline tron9000
« Reply #3 on: May 22, 2015, 07:57:13 pm »
Fair enough, its only as good as the platform  and drivers its build on.
But USB is everywhere now. ok you can buy a GPIB PCI card, used as low as £30, but some are going for £80-£100, seems to be even more if you want PCI-Xpress. USB-A to B cable, most of us have floating in a drawer somewhere, practically free. When was the last time you saw a GPIB card on a PC - scrap that, you probably have one! ;D
Ok you can get USB to GPIB converters too, cheapest I search for was £78.
Anyway this is not to put off houkensjtu of his purchase, looks like a good score.
Offline c4757p
  • adieu
« Reply #4 on: May 22, 2015, 08:15:30 pm »
It's a simple parallel bus. Grab a bloody Arduino or something, and a service manual from one of the early GPIB instruments (they often had a section that explained it in detail, and was quite easy to understand) and just make your own. It's not hard to shove some bits out.
(Was going to say that these are relatively cheap, but, I suppose an HTTP 500 error is really cheap ???)
Offline JacquesBBB
« Reply #5 on: May 22, 2015, 08:34:29 pm »
If you have the floppy disk, you can use  it to save plots in postcript  and print it later on using a computer.
This is what I am doing with a TDS460 (4 ch version). Very convenient.
Its quite easy to find some old floppy disks around.
Offline houkensjtu
« Reply #6 on: May 22, 2015, 10:48:58 pm »
Haha your picture is funny, but for now I DO WANT such a shelf cause it just take too much space on my desk...
And you are definitely right, I bought myself a pair of probe.(see the attachment)
The quality is quite decent, plastic parts are well-made, also packed with a plastic screw-driver which is really handy. Cost me another $13... :-X
Offline houkensjtu
« Reply #7 on: May 22, 2015, 10:51:30 pm »
Thank you for this information!
Actually I'm a linux user so I'm extremely happy with postscript figure, but unfortunately who has a floppy driver nowadays...
Offline houkensjtu
« Reply #8 on: May 22, 2015, 11:01:33 pm »
That's true. I didn't consider about that yet, £30 is absolutely not cheap.
The reason why I'm exciting about GPIB capturing card is that I've been writing some simple data-acquisition program in python, in our company's lab.
Also there is more than GPIB interface, actually there is a RS232 port so I think it maybe fun to make my own rs232 cable and observe the serial communication waveform on itself!
Offline houkensjtu
« Reply #9 on: May 22, 2015, 11:05:20 pm »
Yeah that sounds exiting!
I really want to dig into the serial communication area and that's one of the important motivation for me to buy this scope. I've heard that usb waveform are really fast and crazy that can not be observed by normal oscilloscope, how about GPIB siganl?
Offline dom0
« Reply #10 on: May 22, 2015, 11:25:38 pm »
Depends on what speed you are after. 1 or 11 MBit/s are easily observed with medium bandwidth scopes (100+ MHz), you need, however, proper probes. For Hi-Speed (480 MBit/s) a really fast scope with at least 2 GHz bandwidth is to be used ; there are lots of information about how to test USB connections and what kind of text fixtures you need out there.
GPIB waveforms are generally not overly fast (TTL outputs with quite some capacitive loading), expect rise times in the order of 10+ ns. The fastest response in a GPIB system is the response to ATN (limit: 200 ns).
