Hello all,
Inspired by
http://users.monash.edu.au/~ralphk/slotted-line.html I'm about to build a 1.5 m slotted line to do rx-only antenna measurements at about 150 MHz. So far it seems that one can easily be built from (US) standard copper water pipes by placing them coaxially, diameters here ->
http://en.wikipedia.org/wiki/Copper_tubing . If I pick 3/8" pipe for the inner conductor and type L wall thickness then pipe diameters for the outer conductor will be 1" and 1.25". I calculated the impedance of the resulting line (air-filled) to be 43.04 ohm for the former and 55.65 ohm for the latter. The question(s) I have to the knowledgeable folks are:
1. Is this impedance too far off for measurement purposes? If no, which one of the two is better? The other question only makes sense if the answer is yes.
2. What is the good impedance range to aim for? I can play with other available diameters mixing metric and imperial stock to get close to 50 ohm if necessary. This, however, will make the apparatus more expensive.
I can make parts accurately - to ten thou with no difficulty and to one thou with so if there are other ways to arrive to fifty ohms like milling a slot with a specific width or offsetting the inner conductor I can do this too.
Thank you for your time!
Regards,
Oleg.
