I'd like to use an
ATtiny1634 for a battery powered RTC. This
application note from atmel explains the idea: an external 32768 Hz crystal drives a timer, which overflows causing an interrupt which wakes the CPU up. The CPU does its things and gets back to sleep.
In my case, I'd like to power the circuit from a CR2032, whose voltage varies from around 1.8 to 3.1 V. A graph at page 230 of the attiny datasheet shows the interval of safe frequencies vs Vcc. Therefore I should choose any frequency below 2 MHz.
Since I have size restraints, I won't add an external crystal and I'll just use the factory settings (internal 8 MHz oscillator scaled down to 1 MHz). First stupid question: is the graph valid for both external crystals and the internal one? Will I be fine running the internal oscillator @1.8 V?
Secondly, just for the sake of understanding, let's suppose I use an external 2 MHz crystal. Would this choice lower the power consumption? The CPU would do its job faster therefore going back to power-saving sleep mode sooner, am I right?
EDIT: I realized that the attiny1634 doesn't allow a separate oscillator for the counter, therefore I should use something like a ATmega48PB/88PB/168PB. Page 306 of the
datasheet shows the upper limit for 1.8V operation to be 4MHz, apart from this my questions still hold.
