Trying to select an op-amp that'll do what I'm needing.
- Dual supply capable, e.g. +12v & -12v (or 15v if I can find one)
- Source at most 120mA at the output with the output capable of staying fairly close to the rails, but by no means is it a requirement to get right to them...
- Maximum gain will be about 10, no more than that
- Maximum frequency input of about 20khz
Looks like the TCA0372 will handle what I need.
Trying to understand GBW now.
The datasheet says GBW is .7Mhz thru the range of the device. If I'm reading it right, this means that at unity gain, I can feed a 700khz signal thru it without getting too much distortion. Similarly, if I'm trying to get a gain of 10, the maximum freq the opamp will work at is about 70khz.... Freq of input X gain = GBW...
Is it that simple? I realize there's a bit of a fudge factor in anything like this (e.g. the GBW will likely vary with varying conditions, power supply, input impedance, output impedance, etc). So, is that simple Freq X gain = GBW a decent rule of thumb to go with?
