Having started designing a new project, I've realised that transistor selection and circuit design is something I know very little about. In the past, I've just used common parts that happen to have the current capacity I need, and matched it with a commonly used resistor value to switch it.
I've had a search for tutorials that cover this, but all I've found so far are basic guides to how a transistor works.
Does anybody have any suggestions for any suitable tutorials?
For the specifics of my current project, I'm wanting to use a shift register to power a bank of relays. The relays will have 5V coils, and draw about 50mA.The shift register can drive about 20mA per pin, but is limited to a combine draw of around 70mA, so is limited to a useable 8mA per output.
So given those figures, I've currently picked a SOT-323 transistor capable of 600mA (I'd rather over spec, than under spec), but how do you actually calculate the resistor value for driving the transistor?
Simply use the 5V and 8mA, to get ~825ohm, then multiply that by the gain of the transistor, or do you have to make some allowance for volt drop across the transistor (Which I assume is where all the performance charts in the datasheet come in)?
The transistor I'm currently looking at is DiodesZetex MMST2222A-7-F (RS link -
https://uk.rs-online.com/web/p/products/8233141/)
