1. I have a weller soldering station & need to search between right soldering bit.
2. I have to select bit for WSP-80.
3. I solder component liken QFP , SOT-223 , So-8 , TSOT23-5 & smd resistor & caps of 0603 , 0805.
4. I have attached the pdf for the range of bits from which i can select.
5. I have reading below website:
http://www.hakko.com/english/tip_selection/work_drag.html#type_bSo I think Shape B will be best suited for my requirement.
6. So from attached choices,I have chosen
"T005 44 489 99 , LT 1A , Round tip , width - 0.5mm , length = 14.0mm"
7. Any suggestions?
