Without a schematic, kind of hard to tell. If you have a single power supply, connected to the op-amp will certainly exhibit problems. if you bias the op-amp to 7.5 volts you could swing about +/- 5 volts. Best solution is to get dual 15 volt supplies (+/- 15)
paul
