Thanks,
If the sense resistor is placed just downstream of the mains rectifier bridge, (as in the attached schamtic) then it shouldn’t matter whether the sense resistor is placed in the [DC Bus –ve] or the [DC Bus +ve]. Either place should be equal from a noise point of view, since each node alternately connects to mains live then mains neutral.
However, even in this case, I always seem to see less noise when the sense resistor is connected into the [DC Bus –ve]. Do you know why?
