Thanks guys,
I did some digging.
I found the house had a few gfci outlets, a lot of two prong outlets, and some three prong outlets (at least one in each room). I busted one of each open. Three prong outlet did have a bare copper wire attached to it. This has to be earth ground. The gfci had some sort of a bare copper pigtail but I couldn't tell what it was attached to (maybe the neutral?). And the two prong just had two wires going to it.
In the kitchen there is a fuse box with actual tubes in them. I thought this was what I was going damn damn damn about above ^^^. But then I went outside and saw a general electric box. Opened it up and there was the circuit breaker switches with all the rooms and high power devices on them.
I'm not good with houses yet so here goes a stupid assumption. It seems probable that the old fuse box is just sitting there not in use. I'm also assuming that the reason for the two prong outlets being the majority of outlets all boils down to one thing. Money. $$$.
There's at least one three prong in each room. I'm going to assume that the home owner wanted to cut corners and save some money on here electrician bill when the house was updated. What do you guys think?
From all this, I would think that I'm good as gravy!
