I've read through many of the debate threads on buying a SH CRO vs new DSO as a first oscilloscope. The consensus appears to be to get the DSO. However, it's been mentioned that the CRO is better for those who only fix old analog gear (tube amps). But I haven't seen it mentioned why this is. Does the CRO have some sort of advantage over the DSO when fixing vintage analog audio gear?
For fault finding,many of the advanced features of modern DSOs are unnecessary.
For instance,if you are looking for a dc voltage of,say,100v,most of the time,you don't really care if it is 98v or 102v,or whatever---it's there,doesn't have huge amounts of ripple,or it has the required signal on it.
You move on to the next test point.
if you need to look at "eye diagrams",or find a "runt pulse" in a pulse train,save screen shots onto your PC,read off voltages,risetimes,etc ,without having to measure them off the screen,or a myriad of other things,something like the Rigol DS1054Z is for you.
DSOs in that class are
relatively inexpensive in some markets at around $US400.
Not so cheap in others--$A600 in Oz
OK,you may say,that translates to $US432----but we don't get paid in $US!
Six hundred bucks is still just that!
Most CROs do have quite rugged input circuits,so the chance of damage is less --besides,would you rather cook one channel of a second or third hand $50-$100 CRO or a nice new DSO?
If you go looking for a CRO,ignore the halfwits who try to charge $400+ for an analog 'scope.
You don't need "calibration" for fault finding,so don't pay extra for it.
If you do,in the end,go for a DSO,be prepared to spend enough for a good bench 'scope---not one of the cheap "pretend" things.
