Author Topic: Shift registers, and switching pos vs neg side.  (Read 1579 times)
Offline Barnys1Topic starter
« on: October 29, 2016, 04:20:22 am »
Hi
I have been considering using an Audrino, Pi etc to switch a few relays and had settled on a shift register (e.g. 74HC595) coupled to a ULN2803 which (as I understand it) controls the relay by switching the neg side of the relays coil.
However, I have access to some (cheap) 5V, 403mW, 2 coil latching relays (RT424F05) which have the coils sharing a common ground.   http://www.alliedelec.com/m/d/ac6e4de0241f77689527aa59e6c4b307.pdf
I have fond countless examples of people achieving shift register switching by controlling the neg side of the “to be switched“ components, but I have found surprisingly little on shift register being used to switch a circuits pos side.
Is there something similar to the ULN2803 that I could use to switch the pos side of the relay coils?
Also, in my limited understanding, I thought that all things being equal, it is better to place a switch on the positive side of a circuit, is this correct?
Regards.
Offline matseng
    • My Github
Re: Shift registers, and switching pos vs neg side.
« Reply #1 on: October 29, 2016, 09:38:43 am »
According to the datasheet the 2-coil version have the A3-terminal as a shared power, not a shared ground. So you should be able to continue using the ULN28xx.
Offline Ian.M
« Reply #2 on: October 29, 2016, 09:46:47 am »
If you really need a high-side equivalent to the ULN2803, look at the MIC2981.
Offline David Hess
  • DavidH
« Reply #3 on: October 30, 2016, 04:51:24 am »
Low side switching has the advantage of easily using NPN bipolar or n-channel MOSFETs which are more economical than their PNP and P-channel counterparts.
