You could always make one as a project, maybe use the XR2206 chip. The chip only costs around 8USD, and there are plenty of open source circuits floating around for making a pretty good generator with it. Depending on what you have in your parts bin, the whole thing could cost you next to nothing.
They are quite useful, depending on what you do. Signal injection/tracing is quite useful for diagnosing circuits that aren't working, you can also use them to find out what kind of transformers you have in your parts bin or salvaged ones (i.e. their turns ratio), you can use them to for comparing audible signals, or as a temporary oscillator/timer while prototyping, you can even use them to test things like LC filters. I'm sure there are a lot more uses, those are just the ones that came to mind.
