Apologies for the double thread post on SLA batteries.
If you read the other thread then you'll know I want to put a (relatively small) SLA battery on my pedal bike so I can power heated gloves and a few lights. Unfortunately, this is mostly going to be useful in the winter (short, cold days). We often reach temperatures of -20F that's ~-30C for the rest of the world (or 243K for the chemists!), and I was wondering if it'd be worth it to run a strip of insulated NiCr around the battery and in the enclosure to keep it say, above 5C. I know drawing current will produce heat and therefore warm things up, but I'm not drawing that much current.
It shouldn't be hard to put a comparator with a voltage divider and a temp sensor that outputs voltage to turn on a circuit around 5C. I could use some high value resistance NiCr so that it doesn't draw a ton of current and doesn't get hot enough to melt anything. So, is it worth it? Imagine I wasn't using free batteries and I wanted to preserve the battery, would I do it then? Would it be worth it to keep the enclosure warm in terms of battery capacity saved vs. capacity used to heat?
