Hi, while we are at it, I'll be seeing an analog generator on Sunday, I'm acctually going to look for a power supply, but as I'm at it the seller offers the generator as well and I'm after one too. The main drawback is it's 2MHz only, but it has quite a lot of features not present in the most basics generators. Sweep generator, AM, and more interestingly, in the back, VCF in, CFV out, TTL output and modulation input. I leave a few pictures from google and the link to the paused publication as I go to see it. The unit is a Leader LFG-1300S
https://articulo.mercadolibre.com.ar/MLA-738623741-generador-funcionessweeper-lfg-1300s-leader-japon-mlab-_JM The price is about $140, it's likely U$ goes up tomorrow as we are going through rough times so the price might drop, and I can probably get a nicer deal as I get the two units. (A power supply, old school, also branded Leader, LPS-152 tracking ±25V 1A and 6V 5A) Both units are very well documented and maintenance doesn't seem so hard, in case something happens, pretty trustable units, recapping it might not be a bad idea. There are quite a few of this Leader things on fleabay, the price for the PS agrees about there with international prices, which is a great thing here. The price for the sig gen doesn't, is a bit higher but looks in really good shape. I'd be getting a 6800 for that money, which sounds tempting for the features, but the reliability of this seems much higher and I could probably sell it for about the same later, if it comes to that. I haven't seen much about it online, no good reviews or testing, some repairs but nothing too trending to one failure mode, dirty switches mostly.
What do you say? Should I go for it? Note that I don't have any gen, using my phone for that so far, 2MHz is a great upgrade. The possibility of selling it again is also there so I'm not too worried if it's all working fine, and I'm going to test it before bringing it home, which is great!0
JS
