I filled in memory depth for last one, was still editing post
It can be but that's entirely dependent on your needs of:
Arb wavelength and signal fidelity.
If you you have high expectations select SDG2042X
Ordinary usage requirements, SDG1032X.
But you may have missed sine vs square wave spec of which only SDG10*2X do both sine and square to max frequency.
Then to complicate your decision more, both the X models can apparently be 'improved' beyond their rated BW but as a distributor I'm not supposed to know anything about that.
Check respective threads about 'improvements' for these X models.
* SDG1032X or 1062X models.
Maybe it is my difficulty with English, but I am having a very very hard time understanding what you are trying to say.
Where is this "max frequency" problem?
SDG1025 has sine and square frequency range 1 uHz - 25 MHz.
SDG1032X has sine and square frequency range 1 uHz - 30 MHz.
SDG2042X has sine frequency 1 uHz - 120 MHz, and square frequency range 1 uHz - 25 MHz.
The SDG2042X max frequency for sine quite high, but lower for square, compared to SDG1032X, and same as SDG1025?
The SDG1025 says max frequency is 25 MHz, both sine and square match that max.
Max for SDG1032X is 30 MHz, both sine and square match that max. (So why do you say only SDG10*2X does it?)
Max for SDG2042X is 40MHz, somehow sine is above this, square is below this. I believe this is what you point to as "trap"?
Why did you ask to look up sample rate, vertical resolution, memory depth?
