Hello,
I'm currently designing a 915 MHz oscillator. I want to use a small DFN RF amplifier in my circuit. I've never hand-soldered a part with a thermal paddle - and normally I'd just pick another part, but since this project is on my own time, I'd like to explore outside my comfort zone. I do have a hot air gun.
The recommended layout has many vias to ground underneath the ground paddle. If I laid it out according to manufacturer recs, I don't think I'll ever solder the part correctly with my setup. One, the solder would wick down the vias, and two, my ground plane is an enormous heatsink.
Instead, I was thinking of using silver epoxy on the ground paddle and my hot air gun to reflow the leads. Has anyone done this before? Would it work?
