Rory and Teledog, I'll look into it. Lacy looks promising.
nanofrog, jewelers is on the list.
The probe body is 1.43mm and the tip is .78mm.[1/16" x 1/32"]
The body OD has to be cut down .006" [.15mm] to fit the probe holder.
tautech yes it is the TEK probe replacements and they were silver plated.
I could tin them with solder. tricky- the tinning job has to be very thin.
The idea is to reduce the corrosion by plating- and cosmetics.
Thank you all for your ideas.
