Hi all,
I'm after a small accelerometer acquisition board which needs to be powered at 3.6V in turn from USB or a battery.
Since I'd like to use a rechargeable battery and the tiny cell phone ones are quite cheap, I was planning to use a Li-ion battery, and to manage on the board the charging from USB power.
I see many management ICs, but they seem too complex for what I need: when USB power is present and battery discharged/not connected, then charge the battery and/or power the rest of the board, if there is only the battery, use its power for the system.
Is it really too much to ask for having all of this in a single (and simple!) IC, making voltage regulation at the same time?
I think this is a really common issue.
