hi guys,
i'm not building anything right now, and since i stumbled upon this simple BJT amp stage circuit topology, i'd like to explore it, aiming at having control over achieving the lowest THD. so i tried the following different circuit topologies, where Rb is used to set the gain, and all of them are set to be around 30, in order to facilitate comparison. all questions regarding practicality are purposely ignored.
a plain one, no shunt bias even, used as a reference point for comparision. power supply is 6v.
shunt bias.
worse than just plain.
NFB.
the NFB is done through emitter degeneration, although it is better than the shunt bias case, but still a lot worse than just plain.
12v shunt bias.
the best so far. maybe emitter degeneration is not as effective as raising the supply voltage?
24v shunt bias.
the best so far. this is the first time we can say that's a considerable improvement.
24v shunt bias, Long Tail Pair input.
that's a much better THD number, absolutely the best in this study.
here is a summary
(note: the 12v roll is wrong, the THD in the schematic is correct, it should be 0.0858%, not 0.858%)
Observations:
1) shunt bias messes up the THD, the negative feedback provided with this topology does not help THD, it only seems to do the opposite.
2) raising the supply voltage high enough helped significantly.
3) long tail pair input helped a whole lot!
Question background:
in the long tail pair input case, i got this low THD number, 0.000446%, only by trial and error. values of the long tail resistor, R2, and the feedback resistor, R8, are both very sensitive. a change in value within 1% either way will royally mess up the THD number, so this doesn't seem to be the right way of doing a circuit.
also, Vc of the long tail pair is way to close to the supply voltage, 23.61v vs 24v. i'd like to have it closer to the the mid-point of the supply, but when i try change the resistor values, i was not able to get the THD down to the lowest ever achieved, 0.000446%, not even close, off by 100x or even 1000x.
plus this circuit is ugly, i don't know how i should bias the long tail pair, and DC blocking capacitors are everywhere, etc..
Questions:
1) how could i have control over the long tail pair's Q-point, without sacrificing THD?
2) what are the better ways of biasing them?
3) people say the long tail pair cancels out all even order harmonics, but the 2nd harmonic is still prominent, as seen in the FFT, as is the 3rd harmonic. what techniques can be utilized to at least significantly lower the 2nd harnonic?
4) generally speaking, are there other techniques of lowering THD of this circuit topology?
thank you for all inputs/comments/suggestions/helps!
