Hello,
I built a very simple boost converter on a breadboard and measured the output voltage across the capacitor without a load.
The measured output voltage is 6.2V and the input voltage is 3V (see figure).
I simulated this circuit in LTSpice with the same parts (standard lib) but the output voltage is only 4.5V.
Any ideas what I have to change in LTSpice to get the 6.2V?
Thanks for your help.
Best regards
Momchilo
