PRECAUTION: for beginners watching this circuit, if you dont have enough clue, dont do it at home, or do it under supervision of an adult or expert. we are dealing with 330V of DC potential of naked copper here. more than enough to get you killed under the right (wrong) condition. i did put transparency in between my eyes and this circuit in every powering up.hmm this one seems controversial. let me put the complete picture of what i've experienced last night... actually i want to build a "Mains FG" using bjt opto "switcher" (lets call it "switcher" for simplicity i dont know the precise term, because it will be switched later on), but first, build from simple starting point and test the circuit first. all components are salvaged except resistors and pc817. here's the schematics...
and i firstly built the switcher circuit on the board (perf?) like the following... the rectification circuit is on another board (bottom most pic)
failed! few 1n4007 died on the other board (i was using full bridge rectifier, 2 died at a time, and later just using the half bridge to save the 1n4007). i was about to post a thread about the above schematic, but i found the reason early that the pcb is carbonizing and shorting, i just realized the truthfullness of mike's comment on the other thread. the carbon created a nice longer lasting neon light before BANG! so i redo on another board, dead bug style, should have alot of creepage now. i believed the C4106 and PC817 are already dead by this time since all leads are shorted. but for the sake of RnD i continued since my curiosity is that i cant find any low impedance dc path for the circuit to go BANG. here's the later soldered revision (same circuit like above)..
i put sticky flux on every components so i can visually see if they got heated (smoke), success! no BANG albeit the shorted bjt and opto. but only for 10-20 seconds, the resistors smoking up before another big BANG. all resistors and capacitors survived, persistently the diode and fuse got sacrificed. fyi, diode died without a BANG, it simply silently got shorted, the BANG is on the fuse (small diy copper wires since the original fuse is gone in the first BANG i dont have much spare for this testing so its DIYed).
and here's the subject matter. i removed the "switcher" leaving the rectification pcb alone. i cant find any carbonizing occured. the story and schematic is in the OP. in the bottom part of the picture below is the said capacitor and few dead bodies of diode. i've checked the capacitance and leads continuity of both capacitors involved, both indicating good result. i dont have esr meter.
few responds from this thread:
1)
Would putting a thermister help in reducing the initial surge current?
i know its not the proper circuit, but it still a mistery for me.
the circuit did not failed immediately so i believed its not inrush issue. components yielding is more probable. but in the final test i was using the big fat 6A10 which also failing, reducing the possibility of components yield (maybe? i mean how can a big guy failed even it is old?).
2)
It sounds like you have something wired incorrectly
i've provided the picture for you to judge, i've checked every circuit's nodes to comply with the drawing. this is the first error i checked in every failure and this is also the reason i removed the switcher circuit to rule out incorrect wiring. i believe i wont make mistake for this very simple half bridge rectifier. but eventually it also went BANG, not immediately.
3)
The question is now, what happens at the very first moment after connecting the circuit?
temperature-wise i dont know. i was not touching the circuit while powering up (safety reason
) but as already said, the circuit did not fail immediately.
4)
is not possible that the 6A10 is destroyed the fuse should prevent that, unless you use 100A fuse
i was using DIY fuse later on (copper wire) i put the smaller i have, but i guess its still too big to fail first before the diode, its quite thin though about a hair sized wire.
the diode hum i mentioned was very faint its like vibration on the wooden bench, but if i'm not mistaken, thats the usual mains hum.
