Update: (should anyone care)Thanks guys for pointing me in the right direction. I think I'm close. I actually read your posts this time. Went back several times as a reference.
David, your comment on surge current helped. I get it. I used the fluke in record mode and saw the 1.4A surge. I lasted 2 seconds.
As you said…. One cycle surge…… math….. 2 sec. = more than 1 cycle.
Now I just have to find a rectifier that will do that. ( stocked, that's priced reasonably.)
I also calculated the smoothing capacitor and a regulator.
This site helped me get the concept and the math:
http://www.electronics-tutorials.ws/diode/diode_6.html I made the calculations from measurements using the Peak function of the Fluke 287.
According to Fluke the voltage measurements are "True RMS" From what I have learned Peak is more useful than min/max.
That's my biggest concern. Am I using the right measurements for Vmax and Vrmns.
Even if it doesn't work I want to tinker with it. (When I find the right component.)
