Hi everybody,
I really need simple function generator that can generate sine and square wawe.
Please help me
I need to chose a small resistor. Please help me.
We can only help if you can describe what you really want. Speed. Size. Peak to peak voltage. Price.
Give us at least some basic specification, otherwise we cannot help.
I need this generator for capacitance measurement with oscilloscope.
I think that 5V peak to peak will be fine and a frequency of 100kHz.
It would be great if price is around 10 dollars.
Very good! The 555 mentioned above is perfect for this application.
What I would do is the following: Make a 555 circuit, astable multivibrator, size it to around 100Hz-1Khz. It doesnt have to be 50%, close to it is fine. Power it from a 9V battery. That is cheap, easy, works untill the battery dies. Put a resistor on the output, or even better, a potentiometer, maybe even logaritmic pot.
Connect the ground and the output on the unknown capacitor. Measure the voltage across the capacitor with the scope.
Now, look at the scope plot. You will see the capacitor beeing charged throug the resistor, than discharged. At around 0% charge and 66% charge put the markers on the scope. The time between the two will be the theta, the time constant of the RC circuit. You can measure the R with a multimeter, and you can calculate the C. This is a very educational circuit, this is basically how I did it in high school (with analog scope because they rulez)
