Electronics => Beginners => Topic started by: Telequipment on June 26, 2013, 02:36:44 pm
Hi everyone, I have a need for a sweep generator , but would like to build my own if possible one up to 5/10 Mhz, do any of you have any idea's please.
Paul
Paul,
What kind of output...sinewave I assume
Hi Yes if possible, I have a function generator and one of the inputs states "sweep input", so I wonder if that means sweep generator input or I wonder if it means a Sweep oscillator input, then use the function generators range, either way I don't mind , I'm just at a loss how to go about building one.
Paul
My guess is it's a VCF (Voltage Controlled Frequency) input. The voltage presented to that input determines the frequency. You would feed a ramp signal into that input and the frequency will follow the voltage of the ramp signal.
Yes I've done it, function generator on sine wave 20 kHz then I fed a 6 kHz from my signal generator into the sweep input of the generator, and its sweeping brilliant . Thanks WBB for making me use the grey matter
