Hi, I installed a couple of weeks ago LTspice on linux (kubuntu 14.04 + wine 1.6)
in order to compare the efficiency of a linear power supply vs. linear power supply + mosfet pre-regolator I drew the circuit below
today I noticed that each time I run a simulation (now I just realized it happens with any kind of circuit) I get a slightly different result about the power generated by the "independent voltage generator" (50Hz sine wave) and, of course, of the dependent variables
is this my fault or a because of a stocastic factor added by design in the simulation?
thanks
p.s. I forgot to mention that .meas statements are already embedded in the asc file so you just need to read the simulation log for the results (Ctrl+L)
The problem has been solved
it was probably due to a bug in a library shared with wine 1.6
in the unlikely case might be of help to somebody else:
after realizing that the executable installed in a virtual machine (xubuntu 16.04 in virtualbox) worked as expected, I wiped completely the current wine installation and hidden .wine dir
reinstalling wine 1.6 did not solve the problem, but I had more luck with wine 1.8 and now can go on with virtually destroying electronic components in the simulator
