Hello,
I've some questions regarding my Simulink model shown below. This is primarily for controlling the output voltage of a full-bridge DC-DC converter.
For the top model, I have a pulse generator (340V pulses) to represent the output of the two diodes on the secondary side of the transformer. For the plant, I have the transfer function of the inductor and the output capacitor which also has an 18 Ohm resistor b/c that's what was needed to get a good phase margin.
The bottom model is mostly the same except for a step input that goes to 340V.
I used Matlab's handy pidTuner to find values of kp and ki using the transfer function as the system. These values came to kp=1.022 and ki=4685.
With the lower model, the output looks good, i.e. goes to 340V. However, the top model levels off a 666V. I assume that this is due to the pulsed input and that this top model is not correct. Is that right? Since the output node has a capacitor that can't change quickly can I assume that the step input is ok to use?
What can I do to improve this? For instance, add a controller before the plant to vary the duty cycle based on output V? How would that work in the s-domain?
Thanks.
