just asking if anyone has some cool designs already done
Hi, farmerni
is use this method on a regular basis to save me time. I upgraded
an K40 with a Arduino Mega2560, a ramps 1.4 and the Drivers, running now marlin, because the crap driver board that was inside (especially this Moshi shit) is unusable.
Since then i can produce pcbs with pitches down to 0.4mm. The bottom layer is used as ground plane without traces and i try to use smd wherever possible to save me most of the drilling.
The Layout is produced with KiCAD, the CAM processor is Estlcam which generates gcode from a .dxf.
Total time from a layout to solerable PCB is about an hour (no rush).
But this won't be cheap. In fact the plain Material costs are higher than a PCB shipped from China
