When running an op amp with single power supply, I'm reading that you need to bias your input signal. Makes sense.
Is there a problem due to the bias being wrong by a few percent? Because now the zero crossing of an AC signal is offset from the virtual/effective ground. Wouldn't this cause that part of the signal that is within the offset error to be amplified in the "wrong direction"?
I'm looking at a datasheet that suggests to use a resistor divider to add bias to the input signal. However due to resistor tolerance the bias isn't going to land right at +Vs/2.
