Throw away those electrolytics. Even if they measure OK now, they may die a bit later. Also if voltage was not applied on the electrolytic cap for a very long time, oxide layer becomes thinner. So if you power such a cap with a higher voltage (e.g. half of the rated), there may be huge leakage current. Therefore it may get hot, electrolyte starts to emit gases, and cap may blow up before the oxide layer gets formed. I experienced it myself with some large NOS capacitors.
