How does acetone improve the end result? Are there any other tips/techniques associated with that?
It does not have to be acetone, you can use a number of solvents.
The best i came across is d-limonene (orange terpene, if that is the correct english translation), often sold as label remover.
The acetone will increase the opacity of the toner so the layout will have a higher contrast. In turn this gives you a wider exposure time sweet spot.
The fuser in the printer will not bake the toner properly, the acetone dissolves the toner slightly and when it evaporates toner settles more dense.
I use a brush from the back side because otherwise i will smear the toner because the acetone will dissolve every aerosol pump i have
If you get the label remover you can just lightly spray it from the top side.
Edit:
Here is a comparison picture on transparent film, but it has the same effect on laser printer paper.
http://www.pixelklecks.de/pictures/solvent50.jpgTransparency film may be allergic to acetone, in that case you have to use d-limonene.
By "copy paper", do you mean filled, unfilled, inkjet, laser printer paper, etc?
Normal laser printer paper, the cheapest you can get, because the high end may have UV blocking stuff in it and is thicker.
But it helps if it is smooth paper but it does not have to be.
The draw back is that the exposure time is very, very long.
With proper transparent film the exposure time can be 30 senconds, with laser printer paper its about 10 to 20 minutes.
If you can, you should use the transparent film but im to cheap for that...
What chemicals do you use?
Just NaOH (sodium hydroxide) to develop and Na2S2O8 (sodium persulfate) to etch, both are rather harmless unless you drink it but the same can be said about every cleaning agent in your house.
The NaOH is caustic so eye protection is a must, if you get that in your eye, thats bad news.
The sodium persulfate needs to be warmed to 40° to etch properly but in turn it is translucent and you can observe the etching process.
You can etch with ferric oxide but that is a brown goop, i do not like brown goop.
I would prefer another method of etching but that one can only be done outdoors or in a fume hood. Too much trouble...
Greetings,
Peter
