It doesn't look damaged really, but you seem to state you measured it out of circuit. If it doesn't measure 75 ohms then it ain't no good, doesn't matter what it looks like.
Wondering if the mark on the 5 is consistent with an open SMD. On desk so kinda concerned that if I push to hard with the probe and the probe slips... away goes the resistor. It will obviously never be found again. Appears bad, but never hurts to verify by multiple means- experienced EEs and knowledgeable hobbyists here.
