Author Topic: DIY...ish Bluetooth Mic  (Read 722 times)
Offline skillz21
« on: October 08, 2016, 10:19:29 pm »
Hi guys!
I want to make this, wireless/bluetooth with this. is it possible to do this? also, can i couple two of the recievers/transmitters up so that i basically get a wireless audio... link? (i don,t think its possible, just wondering).
Thanx! :-+
ps.fast responses appreciated :)
"It's only a stupid man, that believe stupid quotes they find on the internet" - Me, 2017
Offline deephaven
  • Civilization is just one big bootstrap
    • Deephaven Ltd
Re: DIY...ish Bluetooth Mic
« Reply #1 on: October 08, 2016, 10:23:28 pm »
Check signal levels, you might need an amplifier between the two.
Offline skillz21
« Reply #2 on: October 08, 2016, 10:27:08 pm »
between the mic and the transmitter? How powerful would it need to be?
Offline deephaven
    • Deephaven Ltd
« Reply #3 on: October 10, 2016, 02:45:02 am »
The spec's aren't too clear, but you might be able to get away with a direct connection. If you don't mind taking a risk, you could always try getting them and see if they work together. If you then need a bit more gain, you could get something later.
