Just checked the facts of the HP 54601A -
there's a big contra on this one: it's maximum sampling rate is 20MS/s, so you'd run it in ETS (equivalent time sampling) for nearly every signal. This works with repetive signals only, and gives you quite slowish display response with higher frequency signals.
The Tek is a quite simple scope, but has a 1GS/s rate and can do single shot captures up to the maximum bandwidth. For general purpose use, this would be the better choice. The Tek's user interface is pretty simple and intuitive to use, don't know about the HP.
Both have about the same sample memory (2k Samples for single shot), so there's no advantage for the HP here.
Edit: the third and fourth channel of the HP have very restricted input amplitude range, not as useful as the first two. So it isn't a real 4 channel scope, it can display only two traces at once - no advantage over the Tek.
So my recommendation would clearly be the Tek.
They are both quite old Oscilloscopes, with the very small sample memory common to that time.
I, & many of my contemporaries were put off early DSOs because the sample rate reduced so radically with the time/div setting.
Trying to look at one field of a PAL video waveform became an exercise in futility as the video waveform contained frequencies well in excess of the reduced sampling rate.
The resulting aliasing gave a display that looked more like my overgrown back yard than the waveform we were expecting.
As long as you bear this limitation in mind, you can probably get good use out of either, but don't ditch the analog--- you may need it to check if your DSO is lying to you.
I like HP, but my preference for 'scopes has always been Tektronics, so, if you have to have one of them, I'd
go for the "tedious 210".
