An IGBT is basically a PNP transistor driven by an N-channel MOSFET. So the input behaves like a MOSFET with a slightly higher threshold voltage.
IGBTs are designed for switching operation, therefore most datasheets do not have any specifications for linear operation. Manufacturers also do not recommend linear operation.
But you can use them for linear operation at low power levels (similar to mosfets, maybe up to 30W for TO220 and 50W or so for TO247 package, depending on the voltage).
