You get energy, not amps.
Are amps not a form of energy? Maybe something was lost in translation.
In discussions like these, you are going to encounter a mix of 'loosely used' and 'scientifically precise' terms. This is one example.
Amps is a simple quantity that is measured at a single point in time. You can create a graph of your amps over time by taking lots and lots of measurements and putting lots and lots of points on a chart. You can then join the dots to create a continuous graph.
But, the fundamental still applies - Amps are a measure of current at a single point in time. The amount of energy that is transported is measured/calculated over an
interval of time, not a
point.
Strictly speaking (and I mean getting into the mathematical definitions), if that point in time is exactly that - a point, then there is no time interval and thus, no energy transported. It's like taking a snapshot of a ball in the air and asking how much kinetic energy it has. You can't do it.
This may seem confusing, but you have to understand that there are a lot of members here, with a wide range of experience, background and 'teaching' ability. Be prepared for these - and if you can work out how to fit all the pieces together, you will not only learn more about the subject - but you will also learn how other people express ideas. Both of these make future learning far more productive.
