Need to test the balls factor on some parts but by way of scientific method. My brain broke down when converting coulums to zipzaps...
Scariest cap ever!
Your question does not make sense for the reasons others have already given. Also, a capacitor does not "charge". It energizes. A capacitor energized to 100 volts has the same net charge on it as it did at 0 volts. For every coulomb of charge added to one plate, one coulomb is deleted from the opposite plate. Capacitors store energy, not coulombs.
Ratch
Hi there Ratch,
From a purely physical viewpoint that may be true, but that limited view will just confuse people who are talking about this from a purely electronic viewpoint. Surely you must have suspected something isnt right by now since almost everyone here questions that kind of statement.
The difference in the two viewpoints, again, is PURELY PHYSICAL vs PURELY ELECTRONIC.
When we talk about the physical nature of the cap itself from an internal viewpoint, we may want to know that the charge is balanced internally. BUT there is a big difference when we view that capacitor from the EXTERNAL world. So here we can say there is an INTERNAL vs EXTERNAL viewpoint difference.
The internal view says that the charge is balanced, but the external view sees it as a differential charge, not an absolute charge. What this means is that we could have 1/2 of the total charge on one plate while we have a deficit of 1/2 of the total charge on the other plate, yet when we view this from the external world we have a view of the total charge which comes out to:
qTotal=q/2-(-q/2)=q
(or we could just say that the total charge is accounted for on just one plate only)
This is similar to when we use a plus and minus power supply (plus Vcc and minus Vee) and measure the voltage from Vcc to Vee instead of from one or the other to ground. We dont get zero volts, which would be incredibly ridiculous. We get the difference:
V=Vcc-Vee
and since Vee is negative if Vcc=5 and Vee=-5 we get:
Vtotal=Vcc-Vee=5-(-5)=10 volts.
THAT is the way we MUST look at it in the electronics world from the viewpoint of an electrical circuit and it's electrical analysis. If we want to know what the cap is doing alone, we might look at that alone, but in a circuit we MUST know ther total charge equivalent which we almost always just call simply, "The Charge".
I dont think i can make it any more clear than that although the more usual view is that we just have charge on one plate that is equivalent to the 'total charge'.
You may want to note that there are other times when we have to depart from the purely physical view in the electronics world. We sometimes have to apply different attributes to the same components depending on the actual application. in modern times this would be called "anisotronic" behavior, where we can not analyze the circuit (note this is particular to circuit analysis) without knowing the multifaceted behavior which depends on the particular theoretical application at hand.
