I'm working on a project run from a 4V 4.5Ah lead acid battery (EnerSys Cyclon series) that needs to recharge via solar panel. The solar panel will be a fixed voltage, but I haven't chosen it yet; I can choose anything between 4.5V and 18V. I'm hoping to find a module for this application, but most lead-acid solar panel charger modules are designed for 12-24V, not 4V. If there's no efficient module, what's the best circuit topology to use?
The battery, by the way, will be driving a couple of low-power analog circuits and a 1.8V buck regulator powering an MCU. ~5mA idle load, ~25mA pulse load from the MCU and related circuitry every .25s, occasionally a ~50-60mA pulse.
