Balance: Black = most negative, Red = most positive, and the whites in the middle are each middle node in the obvious sequence.
Power: The large B- tab goes to most negative, P- is where you draw current from, and C- is the negative connection point for your charger. If there is no B+/P+/C+ pass through (maybe on the back side) then just connect your load/charger directly to the battery +
