I'm not sure how much you know, so bear with me if this is familiar....
There's 3 basic types of flux suitable for electronics use (chemical composition).
1. Rosin based.
2. No-clean formulations; some are made from modified rosin, others from synthetic resins.
3. Water soluble.
Rosin comes in 3 basic types, R (Rosin), RMA (Rosin, Mildly Activated), and RA (Rosin, Activated) from least active to most active. No-clean is also good for hobbyist electronics use as well, but be aware it is harder to clean. Either of these can be left on the boards or cleaned off if desired for cosmetic reasons or there is a specific requirement for doing so, such as high impedance.
I wouldn't recommend water soluble flux for hobbyist use however, as it must be cleaned off in a timely manner or it will corrode your joints. Best to just avoid this stuff entirely. And whatever you do, stay away from acid flux or plumbers flux (i.e. zinc chloride or ammonia chloride) as it's not suited for electronics use at all.
Just stick to quality brands, such as:
- Multicore (Henkel)
- Stannol
- Kester
- AIM (American Iron & Metals)
- MG Chemicals
- Indium
- Alpha (older labels may be marked Alpha Metals; Alpha is owned by Cookson)
Not sure which of the above you'd be able to find in your market, as I've no idea where you're located ATM.
That said,
MG Chemicals 835 (liquid RA), is available in small bottles that are reasonably priced which is very useful for hobbyists (125ml and 1L sizes), and is easily found in North America, the UK and EU. Not sure about other markets.
Kester flux is excellent stuff IME (186, 186-18, and 1544 are all liquid & rosin based). Unfortunately, Kester only offers their fluxes in disposable pens or large containers (1gal & larger, up to 55gal drum). It's readily available in the US, and although can be had in the UK/EU, it's expensive as it's usually shipped from the US from what I've seen (Farnell).
For paste,
Kester RF741 is a modified rosin no-clean that's very nice to use (comes in a syringe). Amtech is supposed to be good as well (also a syringe), but the real stuff is hard to find as their distribution is nearly non-existent (highly counterfeited too).
FWIW, I usually use liquid in a refillable brush pen as it's less expensive and gives me better control than the disposable pens.
BTW, if you go into your user profile and set your country, it's flag will display beneath your userID for each post. That way you don't have to answer this all the time, and you get answers faster as well.
