Author Topic: Does a component that requires bakeout before reflow require it for hand solder?  (Read 1840 times)
Offline JoeNTopic starter
  • We Buy Trannies By The Truckload
Component is LQFP-48, MSL-3.  Soldering is hand soldering, not hot air, oven, or skillet.  Generally, do you need to bake it out for hand soldering too?
Thanks!
Have You Been Triggered Today?
Offline RobertHolcombe
No. Components with designated MSL only require baking when being reflowed - hand soldering is exempt because the dwell time is short and heat only applied directly to the component leads.
Thanks, that was what I was thinking.  From time to time I get a few parts from Digikey and they come sealed, moisture indicator, desiccant bag, the whole nine yards.  I prefer to remove the IC from this setup because it is too bulky to store in my IC trays and usually I need to get at the first IC for my project (any part less than about ten bucks I will always get at least an extra one, just in case or for future projects).    I was wondering if this was wise, but I figured if it wasn't leadless then it is something I am going to hand-solder anyway.
