I've got an small LCD screen that one of the LED backlight cables has come out of. So now I've got a hole in the top of the LCD module. The hole is recessed, so the contact inside is inside the module
I know the contact is in there, since I can stick a pin in the hole and touch a wire to the pin and make the backlight come on, but I can't get a soldering iron in there, and attempts of putting a wire with a blob of solder in and then heating the wire up have been a failure.
Any suggestions, preferably without spending too much?
