Please be note, when installing the thermocouple type, make sure the polarity of the sensor output is correct. Incorrect connection might cause malfunction. Check with your DMM and use a fire lighter to heat up the tips.
When you heat it up, the resistance should increase, if it decrease you got the polarity wrong. Swap the sensor pins.
Topic: Soldering handle hack
So I searched two more thermocouple type heater for you ( HAKKO USERS PLEASE AVOID THIS! )Item 230681537349http://www.ebay.com/itm/5x-24V-50W-Ceramic-Core-Heating-Element-Soldering-Iron-/230681537349?pt=LH_DefaultDomain_0&hash=item35b5b0eb45Item 170805536465http://www.ebay.com/itm/5x-1322-Ceramic-Core-Heating-Element-Soldering-Iron-/170805536465?pt=LH_DefaultDomain_0&hash=item27c4cda6d1
