That models iron looks like a Hakko 907 clone handle so that means it should take Hakko T18 tips.
With genuine T18 tips (and that means sourced from a legitimate Hakko dealer) you should avoid any foreseeable problems as long as you don't over overheat or thermally shock the plating off the tip.
You can maintain the tip in the following manner while you work:
Prior to starting use brass wool only to clean the tip.
Prior to soldering the joint add only a slight bit of solder to the tip (aids in creating a thermal bridge).
Proceed soldering the joints, pause to clean the tip if required during soldering.
If done soldering and returning the iron to the holder clean the tip and apply generous fresh solder.
If not using the station further switch it off immediately while solder is freshly applied.
Repeat this when soldering.
Some other tips!
When cleaning with brass wool the temptation is to stab it, instead I just wipe it on both sides.
If the tinned portion of the tip is not bright and clean and balls up solder then it's oxidized so it requires cleaning.
Don't leave the tip for long without fresh solder on it, the solder will help protect the tip from being oxidized.
When soldering a joint heat it and apply solder to the joint not the iron, this is proper technique and will keep the tip cleaner otherwise your just loading up solder on your iron and won't get nice joints.
If you have an analog controlled station, or a digitally controlled one with presets you should be able to quickly dial down the temperature, this can be used as a cheap substitute for standby/power saving.
