It's been a long time since I've used a cheap soldering station.
I really like JBC, but I also like having a good range of different tips, so for home use can't justify them. I suspect if I did more soldering than I do then I'd find a way to make the man maths work. Instead I stick with a pair of Metcal SP200s. I like having two because removing SMT parts becomes trivial. The bits for the Metcals aren't cheap, but there's a good selection readily available at a sensible price and they do manage to get good heat into small bits quickly, not as fast as a JBC but quickly enough for home use.
I've used many Wellers over the years, but for really small work they never quite got it right, and their little irons, whilst not brilliant for small stuff are poor for big stuff. For really big stuff, their big irons are as good as any I've used.
I did have a quick play with an Aoyue recently and that seemed to work ok but wasn't something I'd choose to buy.
