Author Topic: Soldering Station for <200€ (EU)  (Read 19510 times)
Offline Luckymat
« on: May 02, 2015, 04:07:22 am »
Hi guys
i need some advice
i'm looking for Soldering Station
I had ERSA i-CON Nano for few days but i sendt it back becouse it was broken or shitty
here are my requirments:
ESD safe
230v unit (i'll explain more later)
Brand Name (something popular would be good)
soldering station NOT desoldering iron or heat gun
it should last at least 5years
i have 180€ on Hand paying more than 200€ can be Problem i Need Station and some tips
i have seen on German Ebay Hakko fx888D but the onl Problem is that there are only 110/120v Units :(
i Need something testet and not something you THINK will be good
i can't spend 400€ on JBC like Dave has but i think for 200€ i can get something good or very good
i wont buy again Ersa i-con NANO and i'm Kind of scared buying ERSA again ...
and if i can get it on German Amazon it would be brilliant
i hate gettig things from outside EU becouse Zoll (costumers) always force me to pay that stupid 19% when i get something Little bit pricer
i have googled and i didn't find much
any ideas?
Offline Rasz
    • My random blog.
Re: Soldering Station for <200€ (EU)
« Reply #1 on: May 02, 2015, 04:21:32 am »
Would be easier if you described your problems with ersa, its a solid station.
Hakko fx888 will be at least 2x worse.
Offline Luckymat
« Reply #2 on: May 02, 2015, 04:45:52 am »
OK
what i like:
it is really light
avesome iron holder
you can set every 1°C (most Irons can set 10°C)
what i dont like
you Need this stupid sd Card and Software ....and it stics out
no rubber feet ....i
weird iron connecter under Station
plastic...plastic....uhh
what i think was broken:
low thermal capacity in my opinion
on Energy 1 (for SMD) when iron sits in holder temp was +/- 5°C and when i started to solder it was +/- 20°C
the iron itself (PLASTIC) Thing what you hold...was hot i couldn't hold it Long it was to hot for me
my 5€ iron has tip 350-400° and the plastic is cold like it should ...
broken or normal?
« Last Edit: May 02, 2015, 04:47:55 am by Luckymat »
Offline ThomasDK
  • B.Eng. EE
« Reply #3 on: May 02, 2015, 04:49:24 am »
I have had the ersa nano for a few months, and so far it has been great...
Heats up in a couple of seconds, plenty of tips to choose from and great thermal capacity. Tested this by removing a couple of caps from an old computer motherboard, worked a treat.
What was the problem with your nano?
Edit: Just saw your post
You don't have to use the sd card (I have never had one in mine). My handle doesn't heat up, but I have heard the Pico does... Maybe you got the wrong handpiece by mistake?
« Last Edit: May 02, 2015, 04:54:54 am by ThomasDK »
Offline PSR B1257
« Reply #4 on: May 02, 2015, 04:54:30 am »
Well, how often do you operate the station?
For daily work you should consider a brand name like Ersa or Weller. (No idea, what went wrong with your Ersa-unit...)
Otherwise I'm happy with my XYTronic LF1600. It's under 100€ and you get severel different tips for a little budget.
The performance is good as well (of course, otherwise I would't reccomend it  ;) ). It heats up very rapit and you can solder (with a large chisel tip) parts with high thermal mass without any problems.
I'm not sure wether or not this unit last >5 years. I got my unit since at least 5 years or there about, but use it not that often (couple hours per month), therfore 5 years working time is not a big deal.
In theory, there is no difference between theory and practice. But, in practice, there is.
Offline Luckymat
« Reply #5 on: May 02, 2015, 05:39:29 am »
hmm
Electronics is my Hobby and i will solder like 1/2 h daily (like Weekends and hollydays few h a day and other days 5 min to solder a wire or connector i breake
i'll just put it on my list to check it out in some time
Offline Luckymat
« Reply #6 on: May 02, 2015, 05:45:23 am »
i don't think so i' 99% sure it was nano
more Irons pls?
i won't be happy if i buy ersa nano again and i have the same Problems again :(
ideas?
Offline Sigmoid
« Reply #7 on: May 02, 2015, 06:02:51 am »
I have a Weller WS51, which is just a bit above 200 EUR. It's a very nice, minimal and well-built device. All the old radio amateurs and electronics engineers I know own a similar Weller that's probably lasted a decade or more.
Usually thermal capacity is more than enough, the one time it was struggling involved a huge, thick copper backplate screwed on with a 4mm bolt, and a solder flooded ground plane.
Offline Luckymat
« Reply #8 on: May 02, 2015, 06:11:10 am »
i hate These cases too
i have looked it up and i found it on german Amazon it costs 250€
i'll put in on list
but i have to give it thumbs down for stand it dosen't have much funcionality :( but hey it is on Amazon
Offline Rasz
    • My random blog.
« Reply #9 on: May 02, 2015, 07:03:59 am »
broken or normal?
yes, sounds like bad tip or handle
you can look at hakko 951, xytronic lf-3000, or get replacement ersa (probably better than those)
Weller WS51 is nice, but its 30 year old design sold at ridiculous premium due to brand recognition and iconic fanboy status. WD1000 would be another story, but its 360 euro
« Last Edit: May 02, 2015, 07:08:11 am by Rasz »
Offline nanofrog
« Reply #10 on: May 02, 2015, 08:51:21 am »
more Irons pls?
ideas?
The Nano is a top quality station, so I'd say you got a dud (or possibly a Pico; they look identical from the exterior). I'd recommend sending it in for a refund, NOT a replacement if you purchased from Amazon, as they've a nasty habit of putting returned products back on the shelf and resold as new, including defective items:palm:
You can get it here for 198EUR (incl. VAT).
The Weller WS 81 or WD1002 would be closer to the Ersa I-Con Nano performance wise, but based on Amazon's prices, are more expensive in Europe. Ersa actually has the edge on tip quality (Weller's tip QC has been sporadic IME).
I understand the fear given your experience, but do understand, Ersa really isn't garbage.
Offline Luckymat
« Reply #11 on: May 02, 2015, 09:24:16 am »
more Irons pls?
ideas?
hmm you got me thinking
i did so they did give me cash back
when i got my Station is seemed (my english sucks) that it was used ! i was thinking it was production testing but what you said makes sense!
so everybody says that ersa is really good... if i bought it from that site i would pay 205€ instead of 177€
can i be sure that i get Geniue ersa and not "Kind of" broken shit like Amazon did sell me?
Offline nanofrog
« Reply #12 on: May 02, 2015, 09:56:26 am »
It wouldn't look used from any production testing, and that would be done first before sealing it in any packaging. So when you see non-factory applied tape, you can be sure it was opened for whatever reason.
AFAIK, Yes. But you can call or email Ersa and see if they're truly authorized retailers or not.
FWIW, there have been other members that have bought from them before without any issues.
____________________________________
Another alternative, would be contact another member, TopLoser (located in the UK). He sells major brands such as Ersa, JBC, and Weller (Pace too IIRC), and at a notable discount (so you could get a lot more station for your budget, or same/similar to the i-Con Nano for less). A number of other members have purchased from him and all have been happy with their experiences.
Sometimes it's demonstrators, but he tells you and makes sure it's all there if it is (or tells you exactly what is missing if not), and that it works before he ships it. Link is to his user profile above, so send him a PM, and see what he can do before buying anywhere.   ;) Definitely worth the effort.  :-+
Total brain fart for not mentioning this beforehand.  :-[
Offline nanofrog
« Reply #13 on: May 02, 2015, 10:09:31 am »
BTW, take a look at the following thread by JoeBean, who just bought that station from TopLoser (shipped to CAN).  ;)
Got my Ersa i-Con Vario 4!
« Last Edit: May 02, 2015, 10:14:22 am by nanofrog »
Offline Luckymat
« Reply #14 on: May 02, 2015, 07:22:12 pm »
it had no tape on ersa bo...only on Amazon box
i may do so but it is Kind of bad idea...beouse costumers (Zoll) may Charge me and shipping can be pricy...but i think i will contact him
Looks pretty PRO and HQ
Offline nanofrog
« Reply #15 on: May 02, 2015, 07:26:27 pm »
Definitely gives me the impression it was a defective unit that had already been returned.  |O
I'm under the impression that there's no customs fees between EU members.  :-//
Offline wraper
  • Country: lv
« Reply #16 on: May 02, 2015, 08:04:32 pm »
Did it have grounded power plug or just tiny 2 pin thing? If it was like on the picture, it was Pico, not Nano.
Offline wraper
  • Country: lv
« Reply #17 on: May 02, 2015, 08:20:18 pm »
Low thermal capacity in my opinion
Because Ersa shows you a real temperature of the tip, unlike lesser stations which do not have so good heat transfer from the heater/tight temperature control. In I-con soldering stations, temperature sensor is just about 6-7mm away from end of the tip.
« Last Edit: May 02, 2015, 08:26:25 pm by wraper »
Offline jay
  • Country: ee
  • Coder
« Reply #18 on: May 02, 2015, 09:44:46 pm »
I have to defend the cheap Ersa soldering stations.. I have used i-con pico for an year in hobby use. I use almost daily high end JBCs at work so I have something to compare with. I-con is far from the JBC level but considering the price it's great. The stand sucks. The first unit was dead when it arrived, but it was obviously replaced by the shop and the second unit has been trouble free. So they might have quality issues so get your iron from a reputable place with warranty. For serious use or if money is cheap for you - get a JBC.
SW engineer trying to design HW because it's more fun.
Offline Rasz
    • My random blog.
« Reply #19 on: May 02, 2015, 10:00:26 pm »
this is in germany and looks legit (no idea of they are tho) http://www.ersa-shop.com/
Offline Luckymat
« Reply #20 on: May 02, 2015, 10:26:39 pm »
It was Nano is had normal plug on it not this shitty 2terminal one
JBC you say?
I have 180€ on hand getting 200€ more will be really hard...what model you preffer ? Maybe something in ersa nano range ?
If all you say ersa nano or any ersa or weller or hakko is piece of shit and i should get 400€ JBC or whatever else i will try to get that money
BUT
I have to buy some cheapie 5-10! € one to use and getting 100€ will take me like 3-5 months to get (parents should give me more cash xd)
I'm not pro or so but i need quality
Now.i'm soldering through hole but i will solder smd soon and i won't buy any more iron ...
JBC or ERSA or HAKKO ?
Offline JackP
    • TextGear
« Reply #21 on: May 02, 2015, 10:42:31 pm »
I'm just gonna put it out there - do you NEED quality? I understand about buying something that will last, and ignore me if you do a lot (most days, hours per day) of soldering, but I solder ~3/4 days a week with a Hakko 936 clone; I do a little SMD, for which it is fine, but day-to-day through hole. It cost me £20, but it offers temp. control and decent power. Obviously, if you have to precisely control the temp, and solder low gauge wires often, then get a JBC or Metcal. I'd recommend Hakko fx-888d if you were in the USA as a middlemean, BTW.
  It sounds to me like you really want an Ersa or JBC or Hakko station, which is fine (believe me, I want one as well), but you have to think for a moment about practicality - if it takes you half a year to get £100 together, and have £200 on hand, then there are other things to think about. I would prefer to have a Rigol DS1054z + a Fluke DMM + Hakko clone (I don't BTW), than a quality soldering station. Why?, because that would be more practical for me, and the clone works fine. I could spend everything I have on an Agilent entry scope, or a JBC, but I don't because I prefer to have that money for when I NEED it.
  Think about your needs. If you are dead set on a good station, fair play, we all want different things in life. And please don't moan at me for this suggestion, it's just another way of looking at it.
Want to know more about 'scopes? Click here to check out my Oscilloscope Basics eBook series.
Offline jay
  • Country: ee
  • Coder
« Reply #22 on: May 03, 2015, 12:25:49 am »
Isn't it the same handle in both pico and nano? I have noticed that the handle heats up when the iron is not placed properly (carefully) in the stand. The tip easily touches the metal "spring" of the Pico stand, so it's heating at full power to keep the tip hot. The stand simply sucks.
Offline wraper
  • Country: lv
« Reply #23 on: May 03, 2015, 01:40:11 am »
They have the same dimensions but they are different. As well as heating elements. Nano has the same heating element as more expensive I-CON soldering stations, while pico uses cheaper one.
Offline Luckymat
« Reply #24 on: May 03, 2015, 02:46:30 am »
good Point good way but
i have DMM ist BM257
i Need scope but i must wait
i could buy 2nd DMM but i have time i also could buy PSU but i don't Need it soon (LM317 does fine!)
if i bought scope i would pay 200-500 €
and i my case i Need iron NOW
i have lendt already 100€ becouse i did have 30 and i got 50 for easter
if i saved and bought nothing else i could get 100€ every 2 months but i spend like 5-15€ on other stuff and 5-30€ on components
i my case i Need good iron for few years and scope i will buy in some time
hmm could be it but i liked nano stand it was not awesome but good enaugh
« Last Edit: May 03, 2015, 02:49:12 am by Luckymat »
Offline JackP
    • TextGear
« Reply #25 on: May 03, 2015, 02:56:54 am »
I bet your point, you want to make one purchase and then not think about it again. There are two ways to build up a lab IMHO (for us on a budget anyway). First, buy great gear which will last you, SLOWLY, one at a time. Second, buy lesser quality stuff, so you have something when u need it, but run the risk of having to upgrade. I like the second way, as I love looking at gear that I could get! It will cost more in the long run, but I need a scope, DMM, soldering iron etc. NOW for projects.
  Besides, the clone has lasted for 1 1/2 years, and it's still going strong. It works.
Offline ThomasDK
  • B.Eng. EE
« Reply #26 on: May 03, 2015, 05:24:32 am »
That's where I bought mine :)
Offline Rasz
    • My random blog.
« Reply #27 on: May 03, 2015, 05:33:49 am »
wait what? Im sensing some language barrier here
Offline Luckymat
« Reply #28 on: May 03, 2015, 06:33:55 am »
you are right i want to buy once .... it saves Money (depends how you look at it)
i don't want to die becouse i bought some garbage (like 5€ DMM that exploaded in my Hand while messuring 230v Mains (it was plugged correctly....anyways it's another Story..)
1.5years that is good score for Fake Station !
i mean that i will buy whatever you all offer if everybody says brand X is shit(or garbage...) i won't buy it
i don't have experience with soldering stations i don't know what is Good what is bad ....
i'll try to use other words than Shit ....Google is my best friend ...
Should i get I-Con Nano other ersa or Hakko or wait and buy JBC ? if so which one?
sorry but i won't buy any Fake Station only Geniue One ...
« Last Edit: May 03, 2015, 09:27:18 pm by Luckymat »
Offline nanofrog
« Reply #29 on: May 03, 2015, 10:56:58 am »
If all you say ersa nano or any ersa or weller or hakko is piece of shit and i should get 400€ JBC or...
These are quality brands. Do keep in mind however, that there are different models at different price points. So you don't want to compare an entry level station, such as the Hakko FX-888D or Ersa I-Con Pico to anything from JBC, or the top end from Hakko, Weller, Ersa, or Pace.
There's also the unfortunate issue with pricing in Europe. Still, you don't need to spend 400EUR to get quality. But it will take ~ 200EUR.
whatever else i will try to get that money JBC or ERSA or HAKKO ?
Do note that Hakko isn't widely available in Europe, so they tend to be overpriced. If you are interested in a Hakko, I'd recommend going to Batterfly (their FX-888D page <98EUR; they also offer it in silver>). If you want a better performing station, take a look at the FX-950 (not as many features as the 951), FX-951 or FX-100 (same as Metcal or Thermaltronics regarding the heating technology, but it's also JBC level pricing).
Do note the performance of the Ersa I-Con Nano will be noticeably better than the FX-888D, but it's also ~2x the cost.  Performance wise, the Ersa I-Con Nano is more appropriately compared to the FX-950 or FX-951 (FX-95x use cartridge tips <tip + heating element + temp sensor combined>). Cost & features are more appropriately compared to the FX-951 due to the digital interface & setback features (what it's capable of doing when it's placed in the stand).
The Weller WS81 would be comparable to the FX-950 (both use a knob to set temp), while the Weller WD1002T (includes the WDH10T stand, which has a switch in it that connects to the base unit) would be comparable to the FX-951.
Now since you're in the market for an oscilloscope as well, you should be aware that Batterfly has a Rigol DS1054Z oscilloscope + Hakko FX-888D bundle for 399EUR (scope + soldering station for the cost of a JBC or Hakko FX-100).  :-+ Excellent deal, and well suited for a hobbyist or student on a budget, but doesn't want to end up with garbage.  ;)
A number of members in Europe have purchased from this seller with positive results, and they're the cheapest source for both Hakko and Rigol in Europe I'm aware of.  :)
If you've the funds available, or will in a reasonable amount of time, you should seriously consider this ^ bundle offer IMHO.
Offline Luckymat
« Reply #30 on: May 03, 2015, 09:43:12 pm »
thx thx thx!
you'r blown me
that not a bad idea at all!
will it be shipped from EU so i don't have to pay that stupid cosumers Price?
is that hakko fx888D good enough for smd and so on? i don't care about heating time but i care about Quality and will it last?
Dave showed original. fx888 and it lasted him
is this scope Software upgradable? I mean how much does upgrades cost? 24M memory and 100Mhz?
4 chnnels are awesome!
« Last Edit: May 03, 2015, 11:58:12 pm by Luckymat »
Offline nanofrog
« Reply #31 on: May 03, 2015, 11:55:10 pm »
If you're asking about Customs Duties (import fees in addition to VAT), NO, they don't exist between EU countries. So since Italy and Germany are both member nations, you won't be billed such fees.  :-+
With the right tip, it will do SMD or thru-hole.
Just keep in mind, it's not the most powerful station. So you may find instances where it's just not enough, such as 4+ layer boards (i.e. power & ground planes drawing off too much heat). They all run into this at some point, but the FX-888D will see it faster than the Ersa Nano for example.
Yes, the firmware can be upgraded. It can also be connected to a computer (USB or LAN) and data imported into software, and commands sent to the scope.
It can also be hacked to permanently enable all of it's installed options (100MHz, 24M memory, decode options, ...), making it the best deal for a hobbyist oscilloscope right now.  ;)
Offline matts-uk
  • select * from user where clue = null
« Reply #32 on: May 04, 2015, 02:18:11 am »
I used to work in PCB assembly, back in the early 1990s.   I have an ESA certificate in a draw somewhere, which qualified me to repair space rockets :)
I have an FX888D.  The pre-sets were a pain to set up but otherwise, after a year, I am happy with it's performance as a solid, no frills, production quality iron.  Certainly nicer than the Weller PU3Ds with bit set temperature control, we were invariably provided with on the production benches and expected to do everything with - Woe betide the wireman trying to blame their iron ;)
The Hakko is fine for the day to day work; through hole, cable making, even SMD using the standard bit with some care and attention.  For anything  hefty, I use a cheap butane gas iron.
Offline rob77
  • Country: sk
« Reply #33 on: May 04, 2015, 04:08:54 am »
my 2 cents...
for hobby use i would strongly recommend solomon SL-20 or SL-30 . it's produced in taiwan and probably marketed under different brands as well.
i personaly use the solomon SL-20, it's in the sub 100 Eur range (70-90Eur depends on seller) and it's a well built unit with good thermal mass and regulationl.
and if i'm not mistaken.... i seen a SL-30 on SeanB's bench in the bench/lab thread ;)
Offline wraper
  • Country: lv
« Reply #34 on: May 04, 2015, 04:28:34 am »
my 2 cents...
Is this a joke? But seriously, for the price they really suck.
Offline lastwarrior
« Reply #35 on: May 04, 2015, 04:32:11 am »
Take a look to Lukey 852D+ , it's a smd rework station , i'm using it for almost 1 year... nice station 100$ < x < 130$ range
Offline kxenos
  • Country: gr
« Reply #36 on: May 04, 2015, 05:06:05 am »
I would suggest this
http://www.weidinger.eu/shop/loettechnik/jbc/jbc_loet-_und_entloetgeraete/jbc_compact_line/wl26830
I have one at work. We use it for 6 - 10 hrs per day for the last 8 years. We still have the original 1.2mm chisel tip.  :-+
Offline rob77
  • Country: sk
« Reply #37 on: May 04, 2015, 05:57:07 am »
my 2 cents...
mine looks like and works like a new one after more than a year of intensive usage - i can just recommend it for hobby use - i'm happy with my SL-20.
what's your suggestion in that price range ? i would like to definitely try that one if the SL-20 sucks comparted to it ;)
Offline wraper
  • Country: lv
« Reply #38 on: May 04, 2015, 06:09:56 am »
For a bit higher price something like genuine hakko 888D (more for US) or I-CON pico . There are some other choices too. Or some hakko clone for cheaper. Solomon is just too expensive for what it offers.
Offline Rasz
    • My random blog.
« Reply #39 on: May 04, 2015, 06:11:07 am »
lol no, this is ghetto tool for ulititarian russians, no comparison.
my 2 cents...
nah, Solomons are solid stations. I would easily compare them to older wellers. It will last you 20 years. Trouble is they ARE 20 year old designs (like wellers wes51). There is one opamp, one transistor, one voltage regulator, maybe two capacitors and couple of resistors inside, all connected to old school ceramic heater. Why pay $100 for 20 year old design?
nice, C245 cartridges are 140W = very low resistance = you get 0 to 350 in couple of seconds even in 70W station. T245-FA Handpiece is pretty slick too. not to mention you get two tips with it, tips and handle alone are almost 200 euro, good deal even with basic analog station.
Damn it, now I want one :/
Offline rob77
  • Country: sk
« Reply #40 on: May 04, 2015, 06:52:05 am »
the question was in the SAME price range ;) and actually the Hakko 888 doesn't look any robust from the pictures ( i mean mechanically robust ) - and it's 2 part device. having 2 separate footprints on a desk/bench might be a disadvantage - especially on smaller benches. i think the "glory" of hakko 888 more-or-less exists thanks to Dave & this very forum ;)  i'm not saying anything bad about hakko - it might be even the best iron out there (never tried it), i'm just saying it's overly "glorified" here :D
Offline wraper
  • Country: lv
« Reply #41 on: May 04, 2015, 07:16:53 am »
That particular price is not here, not there. Though you can find something decent hakko style at that price. The issue is that solomon is too expensive for what it offers and you can buy alternative significantly cheaper.
Hakko is robust and separate stand is a huge advantage. You place the stand where you need it. I cannot imagine placing the whole bulky soldering station 10 cm away from the PCB I solder. And reaching soldering iron somewhere away when you need it, just sucks.
Maybe particularly on this forum but overall not at all. There just aren't anything of the same quality/performance in that price range.
Offline Rasz
    • My random blog.
« Reply #42 on: May 04, 2015, 08:00:58 am »
at $100 in US?  maybe (would still argue, Xytronic has better ones at this price range), at >$200 from reputable European distributor (if there are any at all, so you risk getting chinese clone) fat no, that JBC linked few posts ago kills it in every way possible.
Offline wraper
  • Country: lv
« Reply #43 on: May 04, 2015, 08:23:03 am »
Therefore I wrote in the previous post:
You can get it from the battrefly for about 98EUR + VAT except shipping (signigicantly differs depending on country): http://www.batterfly.com/shop/hakko-fx-888d-silver
Xytronic seem to be comparably inferior clones at the similar price - significant gap between the heater and tip. Although much better build quality than most of the clones.
Offline Rasz
    • My random blog.
« Reply #44 on: May 04, 2015, 08:42:27 am »
Offline wraper
  • Country: lv
« Reply #45 on: May 04, 2015, 08:51:50 am »
You forgot to say that this tip is for higher end Xytronic soldering stations which do cost more than Hakko 888D
Offline wraper
  • Country: lv
Offline nanofrog
« Reply #47 on: May 04, 2015, 11:01:44 am »
Seriously? It allows more flexibility in placement. You can put the power/control unit out of the way, and move the iron's stand closer to the work.
It's the lowest cost entry level station from a tier 1 soldering station manufacturer. That on it's own may not mean anything to you, as you've admittedly never tried one. Do so, and you'll see why.
It simply comes down to a station that does the basics well (tips actually fit the heater, and the electronics regulate the heat), as well as minds the little things, such as using silicone insulated wire to connect the iron to the control unit. Seems minor on the surface, but it has a noticeable effect on usability. My one complaint with it would be the user interface  being shifted from a simple knob to a digital interface given it's BOM cost allowance (thanks marketing dept.  ::)) .
You're typical Chinese brand station doesn't approach this level of quality for the money. And the exceptions to this are very close cost wise, if not greater. Quality isn't cheap after all...
Offline Carl_Smith
    • MegaMicroWatt - Carl Smith's Blog
« Reply #48 on: May 04, 2015, 12:23:44 pm »
I would love to know where I could buy a Hakko FX-888 in the USA, in the SILVER color.   I would buy a Hakko but I just don't like the blue/yellow fisher price color scheme.   The batterfly.com site someone mentioned earlier is the first place I've actually seen one for sale and I'm not sure about ordering from a site whose default language isn't even English.   :)
Offline Rasz
    • My random blog.
« Last Edit: May 04, 2015, 01:12:48 pm by Rasz »
Offline nanofrog
« Reply #50 on: May 04, 2015, 01:27:02 pm »
I'm not seeing a P/N for a silver model in 120V from Hakkousa.com (Hakko's official US website). The one on Batterfly is a 230V version.
Silver case parts could be had if you're that set on it though (i.e. paint the main shell & replace the control section so you have the labeling). Seems excessive effort & expense though.  :-//
Offline rob77
  • Country: sk
« Reply #51 on: May 04, 2015, 03:37:00 pm »
Seriously ! ;) and please note the word "might" and also the the part "especially for small benches" which you stripped off in your quote ;)
Offline nanofrog
« Reply #52 on: May 04, 2015, 04:47:08 pm »
So you set the stand and control unit right next to/on top of - one another if your bench space is tight. JBC's Compact Line takes this approach by bonding them together in this fashion.  ;) Other brands you can set the stand on top of the station, similar to old Wellers (anything with a flat top on the control unit). Or if you don't want to set them next to or on top of one another (or can't for whatever reason), there's things like shelves that the control unit can be set on. Stand too for that matter.  >:D  :box:
Offline wraper
  • Country: lv
« Reply #53 on: May 04, 2015, 05:40:21 pm »
new models use 413 tips, for example LF-3000/3200/3500 (they start at $110)
Where do they start at $110? I don't know such a place. I only see that handpiece alone do cost $80 (almost as whole fx-888d) on the link you gave.
« Last Edit: May 04, 2015, 05:47:51 pm by wraper »
Offline Rasz
    • My random blog.
« Reply #54 on: May 04, 2015, 05:59:24 pm »
http://www.jameco.com/webapp/wcs/stores/servlet/Product_10001_10001_2143970_-1
of course there is 3 months wait time :D
model one power level up is available tho
http://www.jameco.com/webapp/wcs/stores/servlet/Product_10001_10001_2181503_-1
Offline rob77
  • Country: sk
« Reply #55 on: May 05, 2015, 03:35:27 am »
teach me master how to put the 2 parts of of hakko 888 on top of each other :D any solution involving duct-tape and hot-snot are not accepted  :-DD
aren't we way off the budget here ?
simply admit it - the glorified hakko 888 is not necessarily the best option for everyone.
and among the single footprint there is  one more (and BIG) advantage of single-body soldering stations - you can't push the stand away by accident - the weight of the station won't allow you to do that ;)
Offline JackP
    • TextGear
« Reply #56 on: May 05, 2015, 03:46:22 am »
I don't think this is going to be an issue in real life. Both parts are small, it gives you flexibility when needed, and for the price is very capable. Normally, if something is hyped up (especially by the knowledgeable people here) then there is good reason (ahem DS1054z).
Offline Luckymat
« Reply #57 on: May 05, 2015, 07:45:11 am »
hi
i have talked o my Mom and asked her (again) for money
she was not happy at all  ::)
i will get RIGOL DS1054Z in some time for sure
but now i have to wait and i'm gonna buy 200€ Station
so what you think should i get
or
http://www.beta-estore.com/rkuk/order_product_details.html?p=511
i won't buy hakko 888D for now
just vote or post other iron 150-250€
few People said i should get the ersa one but that JBC Looks interesting too
and i don't care whatever it has seperate holder or not it has Advantages and disadvantages i'll come along with both
« Last Edit: May 05, 2015, 07:47:52 am by Luckymat »
Offline Monkeh
Offline Luckymat
« Reply #59 on: May 05, 2015, 08:02:21 am »
http://de.farnell.com/metcal/ps-900/l-tstation-60w-240v-eu-uk/dp/1560738
Looks OK enough for me
hmm i'll buy whatever gets many votes (so now i have 3 to pick from)
« Last Edit: May 05, 2015, 08:11:20 am by Luckymat »
Offline Rasz
    • My random blog.
« Reply #60 on: May 05, 2015, 08:53:24 am »
no point looking at votes, between those three you will get similar top quality and performance, difference might be in how you like the handle and tip availability (and tip price)
Offline kxenos
  • Country: gr
« Reply #61 on: May 05, 2015, 11:49:20 am »
The tips of the JBC contain the heating element so they're a bit pricey (around 80euro each) but they last forever. Out of the three it is clearly the best, I think. Warm up in 2 seconds, can handle large ground planes and thick wires and they have the smallest tip width of all three. METCAL haven't proved so reliable for me (I use the MFR-1350 desoldering tool and 900 hot air station). In the ersa (old model, don't remember which one, I have replaced 2 heating elements and I think 4 tips in the last 10-12 years so I guess it's kind of reliable. Wellers, in my opinion are the worst of top quality brands, ugly, unreliable and expensive to fix. One other option is thermaltronix. Check them out to see if there is a model that suits you
Offline nanofrog
« Reply #62 on: May 05, 2015, 11:59:54 am »
Easy/lazy method = epoxy (single stage putty types found in automotive parts stores would be really handy for curved surfaces, as it's meant to be used as a filler & can take very high temperatures).  :o  >:D
If you've a problem with that, there's also fasteners.  :P
It was only an example of a station that did a side-by-side enclosure construction rather than separates, which I'm sure you realized was the point.  ::)  :-DD
But not everyone is on a tight budget, so it depends on the person doing the shopping.  :box:
Never said it was. I would however put forth the concept if a buyer is after a quality, entry level station due to budget restrictions (without being unrealistic), then the Hakko FX-888D is one hell of a value v. the Chinese brands that can be had for less money (i.e. you get what you pay for). Not to say 100% of all Chinese brands are garbage, as they're not. But those that are well made are also priced similarly to the FX-888D.
Now this ^ used to be only valid for the US/CAN market as we were the only ones that could get them for ~100USD, but with the advent of Batterfly selling the 230V EU version for 98EUR, that's changed to include the EU market as well (according to xe.com, the price works out to ~109USD).   :-+
I would seriously have to disagree with you here. I don't have an issue with the stands being pushed away due to light weight at all (mine are heavy enough + rubber feet they I've had zero issues with it skittering across the bench when trying to stuff the iron in).
FWIW, 2 layer rubber ESD mats usually help keep stuff in place as well IME.
Offline Monkeh
« Reply #63 on: May 05, 2015, 12:03:37 pm »
+ delivery + 22% VAT. It is a damn sight cheaper than Dancap at any rate.
« Last Edit: May 05, 2015, 12:05:34 pm by Monkeh »
Offline nanofrog
« Reply #64 on: May 05, 2015, 12:14:59 pm »
or
Both are quality stations, and will give you excellent results.  :-+
There are some differences though, namely in the heating technology used, which has a direct effect on the cost of the tips.
The JBC uses cartridge tips, which means the tip, heating element, and sensor are all part of the tip assembly. Handle is nothing more than a plastic tube with 3 connecting tabs inside to interface with the tips. This also means the tips are more expensive.
The Ersa uses an iron that includes the heating element and temperature sensor, so all that's replaced, is the actual tip (just a plated copper slug). Makes the tip replacement cost a lot cheaper. 3 - 5x cheaper per tip on average (depending on tip profile and what you find for street prices).
From a technical standpoint, the JBC would have a slight advantage in performance only when pushed to it's limits (not often), but would cost you a lot more money to get your tip selection sorted, as well as have an increased tip replacement cost.
Do note that lead based alloys don't etch the iron off nearly as fast as lead-free alloys do, so it's not unheard of to get years out of a single tip for hobbyist users (some have seen 10+ years out of a tip).
This is also a well built station.
Do be aware that the tips on these set the temperature, so if you need more than one temp for a given tip profile, you'll have to buy more than one tip in that size. Sounds strange, but this actually makes sense from a process control POV in manufacturing, as the user cannot change the settings.
For a hobbyist however, this can translate to additional expense to build up a tip collection.
Definitely something to think about, depending on what's important to you (suspect consumables cost are going to be a real issue for you for right now).
Personally I'd skip the Metcal/OKi entirely due to the lack of temperature control, and use tip cost as the deciding factor between the JBC or Ersa. That said, ultimately I've the sense the Ersa would be the best choice for ~200EUR based on what you've posted.
Offline Rasz
    • My random blog.
« Reply #65 on: May 05, 2015, 12:33:46 pm »
they are 20-30 euro now, and like you say they last forever
http://www.jbctools.com/catalegfitxa.php?idpro=890#C245673
there are two tips already included with 210Euro JBC, making it a great deal
Offline continuo
« Reply #66 on: May 12, 2015, 07:58:55 am »
Weidinger does not sell to end consumers, they do only to business customers. So all of the prices on their website are without VAT, which in Germany is 19%... Add that to your 219€ and the price Luckymat had to pay, if they would sell it to him (which they will not), would be ~260€...
JBC soldering stations are hard to get for end consumers in Germany (same goes for Hakko), your best bet is eBay or http://www.chiemtronic.de/ - that's pretty it. That's a somewhat uncomfortable situation, because if, say in a few years from now, you need some spare parts or tips or whatever and these few shops are out of business by then, you may have a problem...
On the other hand, if you buy a Weller or Ersa (in Germany), you always get everything from hundreds of sources without any problems, even a decade or more later. I can even take my bicycle on a Saturday evening, ride the 30 Minutes to the next bigger town and buy me a Weller tip in an old fashioned brick and mortar store. Try that with a JBC tip... They wouldn't even know the company or think of car stereos...
So my advice would be to stick to the well known and supported brands here in Germany, even if the mentioned JBC station may be very appealing, from a pure technical standpoint of view. But broad availability and long term and easy support may pay out in the long run and (at least in my opinion) outweighs slight technical advantages by far...
Offline con-f-use
  • Country: at
« Reply #67 on: May 12, 2015, 07:26:42 pm »
You could build one yourself that uses the excellent WXMP. Or if you prefer self-made Hakko/JBC.
« Last Edit: May 12, 2015, 08:36:09 pm by con-f-use »
Offline Luckymat
« Reply #68 on: May 13, 2015, 07:37:16 am »
I think i will buy that ersa i-con nano (....again)
will it be shipped from eu if i buy it from that site? ( http://www.beta-estore.com/rkuk/order_product_details.html?p=511 )
I will get it somewhere next month
(I won't.close that thread for now becouse i may have problems)
« Last Edit: May 13, 2015, 07:39:30 am by Luckymat »
Offline wraper
  • Country: lv
« Reply #69 on: May 13, 2015, 08:20:16 am »
It seem to be Ireland based. But I wonder, why would you want to get German made soldering station abroad while you can buy it in Germany for less money?
Offline Luckymat
« Reply #70 on: May 13, 2015, 06:33:02 pm »
link pls...
amazon did sell me kind of broken one...
Offline nanofrog
« Reply #71 on: May 13, 2015, 09:12:58 pm »
link pls...
Click on the link, then scroll to the bottom of the page.
At which point you'll find this...
     Beta LAYOUT Ltd. | Bay 98
     Shannon Free Zone | Shannon, Co. Clare | Ireland
     Telephone: +353 (0)61 701170 | Facsimile: +353 (0)61 701164
     E-Mail: shop@beta-estore.com
As mentioned, Amazon has a nasty habit of reselling defective returns instead of sending them back to the manufacturer (even on top tier goods like Wiha & Ersa), and they're marked/listed as new, unopened.
Offline wraper
  • Country: lv
« Reply #72 on: May 13, 2015, 09:27:24 pm »
link pls...
So what? As if the soldering station would be different if bought from different place. Also at least a part of what you wrote was lack of understanding rather than actual fault.
http://www.ersa-shop.com/ersa-icon-nano-elektronisch-geregelte-l%C3%B6tstation-standby-antistatisch-p-364.html
« Last Edit: May 13, 2015, 10:26:29 pm by wraper »
Offline nanofrog
« Reply #73 on: May 13, 2015, 10:08:41 pm »
link pls...
Huh?  :-//
Regarding the station itself, a working Ersa i-Con Nano is a working i-Con Nano.  ;D  :-+ Worst case, it might need a different power cord.
I'm just advocating skipping Amazon in favor of a distributor instead (may still get a bad one, but not due to recycling defective units back into saleable stock nonsense that Amazon pulls).  ;) You won't have any potential issues with warranty support either.
I only posted Beta's physical address to confirm they're based in Ireland as he requested a link for proof. As per why it's cheaper in Ireland than Germany, they're in a unique location, Shannon Free Zone (lower taxes in this particular case), and gross wages are higher in Germany than Ireland (sources =Eurostat and National; after taxes however, it seems the Irish end up with more in take-home pay <lower gross values, but higher net values in Ireland are consistent in both sources>).
Offline wraper
  • Country: lv
« Reply #74 on: May 13, 2015, 10:25:45 pm »
Huh?  :-//
Quoted right sentence from the wrong post  :palm:
Offline wraper
  • Country: lv
« Reply #75 on: May 13, 2015, 10:31:49 pm »
It is more expensive in Ireland, 198 EUR > 177 EUR if I'm understanding maths right ::)
Offline FlevasGR
  • Country: gr
« Reply #76 on: May 13, 2015, 10:55:34 pm »
I just got my Hakko FX888D for 130 euros
Haven't tested it yet cuz freaking 110V transformer....
Offline nanofrog
« Reply #77 on: May 13, 2015, 11:06:32 pm »
The way I read it, the 160.98EUR figure at Beta would have to be before VAT, as is Ersa's 177EUR figure (if I'm reading that correctly; Mein Deutsch ist heutzutage rostig).
Given it's the higher number, that would make Beta's 198EUR figure inclusive of VAT (seems they did reverse net and gross), as there's no way it starts at 198EUR and then drops to 168.98EUR after VAT.  :palm:  :-DD
Offline wraper
  • Country: lv
« Reply #78 on: May 13, 2015, 11:18:13 pm »
177 EUR is with VAT included. The same as on amazon.de http://www.amazon.de/ERSA-i-CON-digitale-L%C3%B6tstation-0IC1200A/dp/B002MQLJ46
Offline nanofrog
« Reply #79 on: May 14, 2015, 12:33:53 am »
8)
I recall reading there was a special of some sort going on from Ersa, but that was some time ago. Guess it's still active. ;D  Doubt EU members would have any issues with a lower price on an excellent station.  :-+
Offline Luckymat
« Reply #80 on: May 14, 2015, 07:07:07 am »
Now i'm kind of confused ..
Can i buy it directly from ersa shop for less than the other one ?
i don't want to buy from amazon this time....the hande was to hot for me to hold plus some other problems.....
if new unit heats up handle i will put sugru or rubber or anything to make it cold...
Offline nanofrog
« Reply #81 on: May 14, 2015, 09:29:37 am »
Seems that the deal Ersa was running is still in effect, so appears to be cheaper than Beta (was under the impression the deal was consistent through distributors though). If you want to be sure, call, chat, or email both before ordering.  ;) Another trick is see what the final price will be during checkout (i.e. go all the way to just prior to entering in payment information).
Either way, you'll have absolute confirmation as to what the final price will be (I find it best to do this anyway, particularly regarding shipping fees).
Offline Luckymat
« Reply #82 on: May 22, 2015, 05:43:45 pm »
Hi
i won't get this station soon (i think i quit electronics)
sorry i don't have time and stable internet and i'll close that thread if i have time
my whole house burned down
http://www.ostsee-zeitung.de/Extra/Polizei-Report/ots-Polizeireport/Polizeimeldungen-Stralsund/Feuer-in-Stralsund-acht-Wohnungen-nicht-mehr-bewohnbar
all money all eq all parts awerything
Offline nanofrog
« Reply #83 on: May 22, 2015, 11:50:36 pm »
 :wtf:
Truly sorry to hear that, and I hope the injuries you and your mom sustained are minor.  :'(  Wish you both the best in getting back into a stable home and financial situation as quickly as possible.  :)
