Author Topic: soldering station METCAL VS PACE ?  (Read 47941 times)
Offline SnakeBiteTopic starter
  • Country: il
  • OBSESSED MODDER
« on: August 06, 2010, 12:21:41 am »
Hello,
i want to buy a new professional soldering station and i cannot decide between the Metcal MX-500 and the PACE MBT 250. they both great MADE IN USA soldering stations, they are both support SMD hot tweezer and Desoldering gun ect (for future upgrade) and they are both very high quality units.
the main difference between them is that the METCAL uses automatic temperature controll tip that raise or lower the temperature by the change of resistance of the part you want to solder (very impressive) meaning that you don't need to change the temp setting  every time you want to solder different part and also you never need to calibrate the soldering station BUT the downside of this method is that the temp remains constant by the resistance of the tip material (i mean the tip temp do change but it remains between a temp range) that's why they have 3 tip models: small , standard and large for difference application.
and the PACE uses regular digital LCD based temperature controll that you can change manualy the temperature.
lets put the price aside for a minute , which method is beter for electronics application
thanks
Ido
Ido Aricha , Israel.
Online EEVblog
Re: soldering station METCAL VS PACE ?
« Reply #1 on: August 06, 2010, 02:54:56 am »
Don't touch any soldering system that is not fully user temperature variable.
If you have to change the tip to change temperature, avoid.
Great for production use, hopeless for general lab/electronics use.
Dave.
Offline Valhallasmith
« Reply #2 on: August 06, 2010, 04:08:03 am »
I quite like my metcal.  I have a PS200 with a few different tips.  Its true that they operate at one temp but its rare that I need to change temp.  600 Degrees is plenty for most SMT and through hole work.  Even when I've use variable supplies I pretty much just set it and forget it.  The metcal hand pieces are nice and light and they have a good variety of tips.  There's a good market on ebay for old tips.  You just need to make sure you are buying a tip that is still good.  The metcal tips are more expensive.  Around 15$ vs 10$ for pace.  And you might need special tips if you need a higher temp for some reason.
I used metcal most of the time when I worked in the industry.  And everyone else did as well.  Sometimes we would drag out a beat up variable Weller if we needed a super low temp. I think a lot of this is going to just devolve into personal preference though.  Technique is going to have a big effect on how well you are soldering as well.
Online EEVblog
« Reply #3 on: August 06, 2010, 04:15:55 am »
I've got a Pace ST25 and a Hakko 936
Both are excellent general purpose lab irons.
Metcal make great quality production irons, but I find them inflexible for lab use. I've had one of those in my lab too, but sold it in favor of two variable temp irons.
Dave.
Offline mikeselectricstuff
    • Mike's Electric Stuff
« Reply #4 on: August 06, 2010, 08:45:28 am »
Sorry Dave but I have to violently disagree here. 'Hopeless' is just bollocks.
As long as the iron has enough power and good thermal coupling to maintain a constant temp with varying loads without overshoot  there is really no need for temperature adjustment.
The Metcal STSSS/MX systems are without doubt the best iron you can buy. I have no experience of their lower-end irons.
I do everything  from 0.5mm QFNs and TQFPs to soldering M4 screw terminals into heavy-copper boards to carry 30 amps with  the same tip temperature - in about 20 years of owning Metcals in a development environment I've never felt any need to have a temperature adjustment.
Can you explain exactly why you think you need temperature adjustment on a good iron? Except maybe for melting plastic.
Day Job: Mostly LEDs
Offline djsb
« Reply #5 on: August 06, 2010, 09:41:27 am »
Which handpiece do you use with the pace? The PS80/90 or TD-100?
Hertfordshire,UK
University Electronics Technician, London PIC,CCS C,Arduino,Kicad, Altium Designer,LPKF S103,S62 Operator, Electronics instructor. Give a man a fish and you feed him for a day. Teach a man to fish and you feed him for a lifetime. Credited Kicad French to English translator.
  • Country: il
  • OBSESSED MODDER
« Reply #6 on: August 06, 2010, 10:09:07 am »
i don't have this unit yet. but i know this model uses the PS-90.
the TD-100 is for more small factor soldering station that they offer (in the size of hakko 936).
Ido
Offline jahonen
« Reply #7 on: August 06, 2010, 10:10:19 am »
Same experience here. Have used the famous WTCP-S for something like more than 20 years I have not needed much to adjust the temperature. Recently got a Metcal SP-200 to complement the WTCP-S. Having a properly sized tip for the job is much more important than compensating wrong size tip by adjusting the temperature higher. Fixed temperature tip has been absolutely no issue for me.
At work we have both types, with temperature adjust and without. The only difference between those seems to be that people just turn the temperature to the maximum if there is something what seems to need more heat and then you'll find the tip FUBAR in no time as they usually don't turn it down when they are finished.
Regards,
Janne
Offline djsb
« Reply #8 on: August 06, 2010, 10:52:07 am »
I used to use a Pace rework station (ST75 I think) in my last job. It was a good tool but was only a single channel so I had to keep swapping over the PS-90 with the SX-80 desoldering pump/iron every time I was repairing anything. Another problem with pace is you can only buy bits in packs of 5. Great if you use 1 size bit all the time but not if you need many different sizes (for SMT one minute and then removing metal sheilding the next etc) and on a limited budget. I've been looking at Metcal SP-200 and one complaint is that they do not have enough power for larger jobs. Bits seem quite hard to find now that the SP-200 is discontinued. Bits can be had on Ebay I suppose but you cant always find what you want quickly and this can delay a job. The MX-500 is way too expensive for me. Now that Metcal is owned by OKI the prices seem to have come down and I'm looking at the OKI Metcal PS-900 (£139 +vat @ Farnell). I'm still not convinced about the merits of Smartheat vs conventional temperature control irons yet. The hakko 936 is also discontinued and replaced with a new funky model that cant be stacked. Suppose I'll have to keep looking.
David.
« Last Edit: August 06, 2010, 10:54:11 am by djsb »
Hertfordshire,UK
  • Country: il
  • OBSESSED MODDER
« Reply #9 on: August 06, 2010, 11:31:47 am »
David.
the PACE MBT 250 has 3 channels on it to attach soldering and desoldering attachments so it's better from this point of view.
so i think that if you want a quality station buy this unit.
Ido
« Reply #10 on: August 06, 2010, 11:34:56 am »
The MX-500 is way too expensive for me. .... I'm looking at the OKI Metcal PS-900 (£139 +vat @ Farnell).
I've often seen Metcal STSS-002's on Ebay for less than £50 - the STSS is functionally the same as the MX500, just does't have the second switchable output. By the time you've picked up a handpice (even new) you'll probably still have change out of 139 and have a more powerful iron.
e.g. this one
Also check other UK Metcal dealers for new prices - Conro often offer good bundled deals with tips etc.
Other dealers : solderconnection
Something else I just stumbled on - looks like the Chinese are now doing knock-off Metcals and tips. They even have a UK dealer
Looks like now the MX5000 is out, MX-500's have got quite a lot cheaper - AMS list a MX500 system at 289
Offline djsb
« Reply #11 on: August 06, 2010, 01:04:06 pm »
Ive seen a Metcal STSS-002 on ebay but there are no details on what power output it has or which bits (that are still available) are still compatible with it. I've looked on the Metcal and OKI sites and done the usual google search but have only found discussions on other forums, no specs. Can anyone help?
Thanks.
David.
London,UK
Hertfordshire,UK
« Reply #12 on: August 06, 2010, 01:20:25 pm »
STSS-002 is for practical purposes the same as MX500 - the only differences are :
STSS has squarer case, MX has a curved front.
STSS has one output on the rear. MX has 2 switchable sockets on the front - only one outputs power at a time. Only useful if you use 2 irons, or an iron and desoldering gun (Metcal's desolder gun is awexome BTW, but needs compressed air).
MX has optional idle timeout to switch off if iron not used for a while (Enabled via a well hidden grubscrew).
I just checked my old STSS against an MX500, and output power is the same, and more than enough for any task - both will get a small tip from cold to working temperature in about 7 seconds.
Both use the same handpieces and tips - STTC and SMTC series.
The new MX5000 comes with a slightly smaller handpiece but is still compatible.
The only other difference is the workstands that come with later models have a magnet to de-power the tip when idling, to extend tip life. This is useful for small tips, but can be a PITA on larger ones due to the warmup time - 10-15 seconds is a long time to wait for an iron to warm up if you're used to using a Metcals!
« Last Edit: August 06, 2010, 01:28:22 pm by mikeselectricstuff »
Offline djsb
« Reply #13 on: August 06, 2010, 01:28:51 pm »
Ok,I'm warming to the Metcal but where do you buy your bits (when you need them). I cant imagine they're available from Farnell or RS.
How is Metcal for technical support and supplying of spares for the older models? Do you have any experience of this?
Thanks.
Hertfordshire,UK
« Reply #14 on: August 06, 2010, 02:44:46 pm »
Metcal tips are available from Farnell,RS, Digikey, but I can't remember the last time I bought them there - most of my 100-odd collection of tips has come from ebay over the years, mostly from the USA site.
Whenever I see any types come up which I use regularly, or look useful, I buy a few for stock, and now probably have nearly a lifetime's supply. In practice the only ones I find have a limited lifetime are the super-fine needle point STTC145's, and that's usually due to me pranging them and bending the end - I maybe get through two a year. Bigger tips typically last years of daily use. Metcal tip plating lasts way better than any other iron I've used - this is probably in part due to not needing to crank up the temperature when doing heavier stuff.
Keep an eye open for the long blade types -SMTC160/161 - these are expensive new, but brilliant for flowing-on and braiding-off whole sides of SOICs, TSOPs and QFPs in one go.  You also want the monste-chunky STTC-117 for those really meaty tasks like soldering TO220 tabs to groundplanes.
One caution - avoid that bullshit leadfree  solder - this does eat tips very noticeably faster.
Make sure any bigger tips you get are -1xx temperature types, especially if you insist on using leadfree. There are some nice 'P' series tip for fine leadfree work, which have thicker thermal paths to the small tip.
-0xx series  are OK for leaded solder at smaller sizes but disappointing in a bigger tip.
Do not under any circumstances buy -5xx tips, however cheap, as these are only useful for speciality low-temp solders and melting plastic.
Offline charliex
  • Car Hacker
« Reply #15 on: August 06, 2010, 03:03:03 pm »
i buy my metcal tips off ebay, there are usually job lots on there, you end up with a few odd ones now and again.
Offline lhc
« Reply #16 on: August 06, 2010, 05:12:24 pm »
Good iron still needs temp adjustment for me. I need to change the temp when I need to solder/desolder something with leadfree (everything mass produced is Pb free in EU and Pb free needs higher temps) and when desoldering using wick - the wick itself is like a radiator and probably makes the termal connection between joint and tip weaker, ramping up the temp gives great results.
« Reply #17 on: August 06, 2010, 09:56:49 pm »
If you'd used a Metcal you'd realsie that it is NOT necessary to increase temperature for things like wick. Lead-free just means you use the right temp tip to start with, which is also fine for leaded work.
I just saw this post on the Piclist from Dwayne Reid which explains things nicely :
Its actually very hard for someone who has not used a Metcal
soldering station to understand that bumping soldering temperature is
NOT necessary when soldering large-mass joints.  Really hard.
I'll give you an example, though.  This was with one of the early
Metcal stations - maybe a RFG-30 or PS2E - I don't recall.  This blew
away the guys in my shop when I showed it to them for the first time.
Take an ordinary copper penny (a real penny - one that can be
soldered).  Place it in the middle of a piece of single-sided or
double-sided PCB material that has been cleaned enough to be soldered
- perhaps 6" square.
Take the smallest Metcal tip that you have.  I think that for me, it
was either a sttc-138 or a sttc-125.  The '125 has a very tiny tip,
suitable for SMT work.
Add flux all around the penny, touch the soldering tip to the edge of
the penny and add a bit of solder to promote thermal
conductivity.  Wait, then start adding solder so that the entire
penny is soldered to the PCB material.  Total time - about 1 minute.
Observe that the tip temperature does NOT go above the set-point of 700F.
Now go and solder a SMT device to a PCB without damaging it.
None of the other soldering stations that we have (had) here could
solder that penny to the PCB material unless we installed a really
big tip - maybe even having to go to an 800F tip in the case of the
Weller station.
Like I said - its REALLY hard for someone who hasn't used that type
of soldering station to understand the difference.
dwayne
Offline cybergibbons
« Reply #18 on: August 07, 2010, 04:35:19 am »
I got a PS-900 a while back, so it's the lower frequency (470Khz) than the more expensive ones (13Mhz?). This means that the hand piece and tips aren't quite as delicate, but it still uses the same smart heat tips. Farnell sometimes put them on offer.
I've never felt the need to have temperature adjustment. It's fine from the smallest to largest electronic parts. I find it's very on/off when you push it too hard, there is a point where it simply cannot put enough heat into the part.
Offline lhc
« Reply #19 on: August 07, 2010, 06:19:57 am »
I can assure you it's not. Pb free needs higher temps. If you will try to solder standard leaded solder with that kind of temp the flux will evaporate instantly (making nice shooting smoke trails in the air  ;D  ) and leave you with an overheated grey joint and the lead will stick to the tip making a sharp point instead of a nice shiny drop. It's also important if you use something like Chipquik to desolder SMD parts (you will probably need to lower your tip temperature especially if you are using tip for Pb free) http://www.chipquikinc.com/newsletters/cq_new_june_2004.htm
But it's not really that important for most of us - it's probably more important for guys that make some repairs, most of us doesn't need to switch Pb/Pb free that often.
The only "magic" is that irons that you are talking about have tip that controls the temp itself. It's small so it reacts quickly on even small temp changes. It's because it has small temp capacity compared to irons with bigger tips and the tip itself is switching the heater circuit (it's magnetic properties change with temperature). That kind of irons have better temp stabilisation than regulated ones.
Comparing irons working in different technologies is tricky. I was wrong when saying you have to ramp up the temp to use wick - if your iron has a quick temp regulation you don't have too, it will detect that and pump more heat. My iron has bigger tips - when the tip gets cooler the end is still hot because the change in temp needs time to propagate thru the whole tip to the temp sensor. I compensate for this ramping up the temp before using wick or soldering anything with big temp capacity.
But now tere are soldering stations with temp adjustment that have really small tips. They should work just as good as the "tip regulated" stations - reaction on temp change of the tip will be also very quick but with added bonus of adjusting the temp for Pb/Pb free and Wood alloy (Chipquik). The tips should also be cheaper - they are not so complicated to make.
Offline jahonen
« Reply #20 on: August 07, 2010, 06:33:58 am »
If you do proper Pb-free soldering, then you can never use the same tip (or desoldering braid) for anything with leaded solder. Even tiny residue of Pb will result a lead contaminated joints, thus no longer Pb-free, and the tip is "poisoned" permanently. So much for "one tip" tactics...
Regards,
Janne
Online EEVblog
« Reply #21 on: August 07, 2010, 07:02:13 am »
Ok, poor choice of words.
They are less flexible and more inconvenient.
Funny how they make all those different temperature tips then isn't it?
Fixed temp, yes, one of the best irons you can buy.
That's perhaps because you are used to using a fixed temp iron.
I've used fixed temp irons too, and you get used to them, just like you do to any iron with different technology, tip types and thermal capacities etc.
But when you have a good variable temp iron you find it's just more versatile and generally don't want to go back to a fixed temp iron after using one for while.
As always, YMMV.
There are plenty of reasons, which is why they make different temp fixed iron tips. Metcal have anywhere from 500F to 800F tips. Why do you think typical tip temperatures are well above the usual melting point of solder?
Which temp tip do you use, and why?
There are all sorts of theory like being able to deliver heat quicker without applying as much pressure for shorter periods, different solder and flux material types, thermal capacities of the parts etc etc.
So a variable temp iron is a more versatile and convenient tool, simple as that.
If you don't have different temp tips in your soldering kit then I'd have to say you are not properly equipped. Yes, you can "make do" with one temp, but it's not ideal for all purposes.
Dave.
« Reply #22 on: August 07, 2010, 07:34:41 am »
Dave.
The variation in metcal tip temp is mostly for niche uses.  If you have a particular process then you only need one line of tips for the most part.  The metcal tip selection doc for my particular model suggests 500 degree tips for heat sensitive parts and no-clean fluxes, 600 degrees for everything else by default and 700 degree tips for bus bar.  I almost always use 600 degree tips though.  I have a small 500 if I really need it.  I frequently turn my metcal on and off so I like the instant heating features.
I think this is turning into an Apple vs PC argument now.  Either one will get you where you want to go.
« Reply #23 on: August 07, 2010, 08:00:17 am »
I only use the -1xx (700 deg.F tips), and a few -0xx (600 deg) which were bought only because they were cheap on ebay.  Metcal make 4 tip temps, but the highest and lowest are for wacky flavours of solder, and the middle two are basically leaded/leadfree.
IMO the ultra tight coupling of the Metcal, combined with the ergonomics of having a very short (cool) handle-to-tip distance and 5-10 second warmup time more than makes up for any lack of 'flexibility', although I've still to see a concrete example of where you'd need it.
Out of curiosity Dave, was the Metcal you used the MX series or the lower-end 470KHz family?
Obviously there is a big personal preference factor, however you're the first person I've ever heard of that has owned a Metcal and decided they didn't like it..
For those who have only used conventional irons, this is something that really needs to be experienced - Dwayne's post sums it up very well.
In the old Pre-OKI days they had a very simple sales technique - they lent people systems for a week. Only about 5% of users didn't buy, and they were probably mostly down to cost.
So what? The only reason for using leadfree is misguided bullshit legislation. If you should happen to have some traces of lead in the occasional leadfree joint, it isn't going to poison anyone and who is ever going to find out? It's totally irrelevant in a development environment.
If you're really paranoid, a couple of wipes and re-tins will reduce the lead content in any joint to below the 0.1% legal limit.
Offline lhc
« Reply #24 on: August 07, 2010, 08:03:56 am »
Regards,
Janne
I actually don't care about lead contamination at all. It is only important for the manufacturer not for me. I care only about higher temp for the Pb free stuff to melt.
